will 16 inch rims fit a 3rd Gen?
Old Nov 9, 2010 | 06:44 PM
bradler's Avatar
can you fit 16 inch rims on a 3rd gen? or will they not clear the tie rod ends?
Still on the hunt for some winter tires and i want a spare set of wheels to mount them on and cheap steel rims are most available in 16inch...
Old Nov 9, 2010 | 06:54 PM
tryNto's Avatar
Will not fit, Won't clear the Brake Calipers...
Old Nov 10, 2010 | 11:33 PM
Dieseljunkie's Avatar
I'm with tryNto. There is a reason Dodge started using 17" wheels when they went to bigger brakes.
Old Nov 11, 2010 | 12:42 AM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
yes they will fit you just will have to change the caliper brackets and rotors to the 2001-2002 pieces
otherwise no calipers stick up too far
Old Dec 1, 2013 | 07:33 PM
tyke's Avatar
16" rims will fit,you need to grind off the front calipers[outward of piston area]and some of the caliper bracket ends.
Much less grinding required for the back to fit.
Lots of material on calipers and brackets so I do not feel there is much or any risk to doing this.
Took me a while to fit the first front and back one[3 hours]because I fitted the rims often,so I only took off what was needed,once I was close I coated the caliper/brackets with white grease,and could see exactly where grinding was still needed.
I also went with 1/4 inch spacers on all wheels and this cut down on a lot of grinding needed,avialable at any parts store,20.00 a pair.
Done the other two in about an hour,i also needed to take the centers out 1/4 inch on the rims I had,which was a minimal job.
Other rims may fit better or worse,i think mine were off a 2001 dodge ,bought them used for 150.00 with chrome trim rings,and my dodge centres still fitted over the wheel nuts same as the original rims.
Have driven it for a week,including hi-way to cottage and back and runs as good as before,the plus for me was I had fairly new studded winter tires[8]from the two old trucks I had,so I can use them now,they are 235/85/16,best tire for plowing in my opinion,and are less then
2% difference circumference then the 265/70/17,so not noticeable difference for speedo,etc,and well within the maximum allowable most tire shops recommend[no more the 3%]
So with a bit taller and much narrower footprint,perfect for plowing and all around traction.
Very happy!
Tyke
Old Dec 23, 2013 | 10:36 AM
crdodge7's Avatar
Hey guys can someone help me I want to put 16" rims on a 2007 dodge ram I have inch and half spacers do I have to do any modification to the calipers or the spacers will help fit better
Very happy!
Tyke
Old Dec 23, 2013 | 04:42 PM
crdodge7's Avatar
Do you think with 1 1/2" spacers I don't have to grind the calipers?
89dieselkong
Aug 14, 2011 08:04 AM
stock03
Dec 23, 2010 12:59 AM
nasty01cummims
Jun 15, 2009 11:04 PM
1qckdodge
Mar 5, 2007 09:53 AM
1320
Feb 27, 2004 06:02 PM
