What 17" wheels DO fit?
Old Aug 24, 2005 | 10:36 PM
tejas58's Avatar
Having just gone through the agony of ordering wheels (Helo 17X9 Maxx 8) and having tires (BFG 315/70 -17) mounted and balanced, only to find they (the wheels) wouldn't squeeze past the front calipers..................I was curious to get some feedback on what 17" wheels will fit on my 2003 2500 4X4 (came stock with the 265s). I saw some Helo Guns mounted with the same tires etc., and THEY seem to fit (and looked pretty good). Also, keeping the wheels tucked under the wheel wells somewhat would be nice - I'm not a serious off roader, so clearance isn't quite as big an issue. Thanks for your time!
Old Aug 24, 2005 | 11:04 PM
UnrulyNFS's Avatar
Man, I really want to know the answer to this as well. How close is the fit? I cleared 15" wheels on my 01 fronts by just grinding the calipers down. Put 25K on it that way with the only issue being NO stick on weights in the area you had to grind.
Really would like to know the answer here guys. I'm dying to get a set of Moto Metals put on mine.
Old Aug 24, 2005 | 11:30 PM
DirtEater's Avatar
Couldn't you get the same wheel you had in an 18"? Weld has a few EVO wheels with 5-1/8" backspace which is about as much as you will find. They have them in 18x8.5.
Old Aug 25, 2005 | 08:40 AM
Dan_K's Avatar
I've got Weld Cheyenne wheels in a 17x9.5. I went to Les Schwab and let them do the dirty work, as they first pulled out a set of chrome Foose 17x9. These fit on the front, but would not fit over the rear hub. They yanked those apart and put the Welds on, took my cash and gave me my warranty, and rotation info.
DK
Old Aug 25, 2005 | 09:22 AM
UnrulyNFS's Avatar
DK
I actually saw this problem on another truck about clearing the rear hubs. I know if the wheel style is made for centercaps, you can just put a larger center cap on. To see what I mean check this site.
http://dodgetruckworld.tenmagazines....ry.asp?id=8997
Old Aug 25, 2005 | 01:03 PM
tejas58's Avatar
I know the safe bet is 18s, but I'm trying to go cheap here. I've got a line on 4 new (they where put on a friends recently purchased truck to help it sell) BFG 315/70-17s for $400, and with the Helo wheels, I can get in for $12-1300. I saw a 2500 with the same tires on a set of Helo Guns, and they seemed to fit OK. Anyway - anybody chip in if they're successfully running aftermarket 17s. Which ones, and what modifications where required (if any). Again, thanks...
Old Aug 25, 2005 | 02:39 PM
caltom's Avatar
I've got 17" American Racing Pythons on mine. No mods needed they fit just fine.
When I was wheel shopping last year, I bought a set of wheels that were 0 offset and they stuck way out. I told the salesguy I didn't want anything that stuck out and was as close to factory specs as possible. After putting them on the truck I didn't like 'em at all and they took them back. The Pythons had the most negative offset I could find. The wheel salesguy and I looked through all the manufacturers catalogs trying to find something close to the factory wheels -30 offset. Without going to a Boyd or someother custom made wheel, the closest we could get was -12 on the Pythons. Most aftermarket wheels will have 0 offset, some will have -6 offset because this fits Ford and Chevy real well but sticks way out on a Dodge.
Good luck.
Old Aug 25, 2005 | 08:52 PM
drew03's Avatar
most places that you purchase wheels at will test fit wheels prior to you purchasing them. I would just decide what wheels you like, and what you can get. i would first test the wheel on the front, if it clears then mount one tire and test on the the truck. If it clears the calipers and bumper, fender ect, you should be in business. most places want a happy customer. I used to work at tire/wheel shop, on my truck some 17's would fit and some would not, like i said you just have to try and see.
Old Aug 25, 2005 | 09:12 PM
BigBlueDodge's Avatar
The Centerline Crossfire wheels are the closests I have found that come to stock. 17" x 8.5" wheel with 6" of backspacing.
http://www.centerlinewheels.com/whee...ehicle&data=11
Add to that they are forged and not cast.
Old Aug 26, 2005 | 03:04 AM
PourinDiesel's Avatar
I run mickey thompson MT2's in 17x9"
Old Aug 26, 2005 | 07:24 AM
tcr's Avatar
tcr
I have had the procomp 17x9s and I now have the moto metal 951s, these are alot like the maxx 8s.
Old Aug 26, 2005 | 08:05 AM
Capt.Dan's Avatar
Take a look here. The H2 wheels with a little mod will work. You can find them on ebay.
https://www.dieseltruckresource.com/...threadid=71520
Old Aug 26, 2005 | 08:30 AM
IrishND's Avatar
Dan_K, what size lift are you running to fit 35's on 17x9? Is there height difference between a 2500 and 3500?
Bob
Old Aug 26, 2005 | 09:16 AM
Dan_K's Avatar
Bob
The wheels are 17"x8.5", and BFG 315-70-17 which I think equates to a 34.5" tire. Everything is stock height. They rub slightly at full lock in reverse. there shouldn't be any height difference between the 3/4 and 1ton.
DK
kiszka6911
Apr 20, 2010 04:18 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
schv
May 2, 2007 09:55 PM
xyzer
Jun 22, 2006 07:44 AM
