weird one
Old Jul 23, 2008 | 11:14 PM
44-40's Avatar
weird one
Bought a boat the other day. We use the heck out of it. only problem is every time I back the boat into the water it blows the reverse light fuse, I figured no problem I would start unpluging the trailer before I back the boat into the water. It still blows the fuse. Its almost like the reverse light is going to ground in the water. Anybody have any ideas or explanations??
Old Jul 24, 2008 | 06:21 AM
mini14's Avatar
u r still getten water in the bulb filiment...takes a while for h20 to evap...try coating the _hit outa the electric contacts with dielectric grease to repel the water....
Old Jul 24, 2008 | 06:55 AM
TMan's Avatar
How far you backing that truck into the water?
Old Jul 24, 2008 | 07:07 AM
Foxborough's Avatar
My boat has hydraulic surge brakes, but does your trailer have electric brakes? If so there is a reverse circuit that disables the trailer brakes when in reverse. If not may want to rewire the whole thing with new lights, water & 12 VDC do not make a nice environment. FYI, I always unplug the trailer before inserting into water and make sure trailer drip dry before pluging back up.
Old Jul 24, 2008 | 08:32 AM
lniemeyer2's Avatar
Check the white wire on your trailer lights, this should be your ground. The white wire on the trailer should be connected to the frame of the trailer and the white wire on the truck side should go to the frame of the truck. Sound like the wiring on your truck got messed up somewhere.
Old Jul 25, 2008 | 05:14 PM
44-40's Avatar
Thanks for the comebacks. The truck has the factory tow package, wiring seems to be in perfect condition, will look at the white wire this weekend after I go fishing tonight. Also, the truck doesnt touch the water . Remember it blows the fuse with the trailer lights unpluged, thats why I say its like the truck goes to ground when the trailer touches the water.
Old Jul 26, 2008 | 10:38 AM
Foxborough's Avatar
So it looks like your truck has a wire wrong. Check the voltage between the trailer and the neutral on the truck, something is wrong. The good thing is that it is repeatable. Put it in the diveway, clamp a wire to the trailer (to bare metal) and clamp a wire to the truck ( yes bare metal) and see if you still blow a fuse. Now something repeatable, pull the fuse that blows and trace it back. Seperate (sp) it , is it the trailer or the truck.
Common
Apr 9, 2008 10:25 PM
ollie32
Nov 8, 2007 05:05 PM
hlc
May 13, 2003 11:11 PM
Wade
Oct 15, 2002 05:29 PM
