Upgraded steering
#361
Alright I'm going to order the steering kit tonight, now couple questions if someone can help
52122362AE---This is the steering kit correct. Includes new tie rods, and everything. Connects from the pitman arm, to the tie rod, and then the other bar connects to the other tie rod correct?????
Also, $224 on dodgeparts.com. Sound good? Also, I will need the new dampener right??? I shouldn't have a problem with a stock Dodge dampener with a 6" lift, and 37" tires right????
#362
Correct on all accounts, LS1. You might need to buy a couple of bolts, nuts, and washers as well; im not sure if they are included with the AE kit or not now. Your dealer parts man should be able to tell you. You will need to either modify your existing damper mounts or buy the new damper. I don't have a problem with the OEM dampers on my truck with 35's. Im going to 37's next and have no plans on replacing the OEM damper with an aftermarket unit until this one wears out (which should be a while since it just got replaced when i had the new style setup installed). I think dodgeparts.com is probably about the cheapest you will find it nowadays.
#365
well i finally got all mine replaced even tho i brought it down for just ball joints, ended up the whole front end got replace, new steering, u joints, ball joints, ss, everything except a wheel alignment wasn't covered but the new parts looks great so much beefier. I just need my steering box fixed which they say is because of my tires. I cannot turn my wheel when i am at a dead stop . Makes it ridiculous to try to turn my wheel when trying to back up my boat or trailer..
#366
ls1....you will need the nut that secures the damper on the stud mounted to the new linkage.Everything else will transfer over.The stock stabilizer will be marginal with 37's.Depending on where you drive and at what speeds may be less than safe.Carli suspension has a high mount kit that will work in conjunction with the stocker
http://www.thecarlisuspension.com/do...tabilizer.html
If you go that route be sure to specify you have the up dated steering one clamp is different
#369
Is there any way I can get this upgraded steering from a O'Reillys or Advance type of auto store? Or is the only way to order from a dealership or online?
I put in the part numbers but can't find the kit on any auto parts store online catalog. Do we have any parts numbers for each piece?
#370
#371
madbull:
You can probably get Dodge CTD CR front end parts from the various auto parts stores, but the part numbers most of us have posted in this thread are Dodge part numbers. They can "cross reference" the part numbers here, to their specific manafacturers such as Moog etc.
John_P
#373
Recall Letter
I just received a recall letter from Dodge. What I am getting from the letter is if they inspect the front end and find that it hasent be replaced with the recalled parts, they wont do the work on their dime. Its an 06', and im sure that its the original front end. Has any one else received this letter that owns a 03'-07. I already bought the new parts from Dodgeparts.com (AE Series). I havent had time to put them on yet. Ant input would be great.
#374
I got the letter. Threw it straight in the trash. I did ours back in January along with new ball joints and other front end aftermarket parts. Did most of it myself, basically rebuilt and beefed up the whole front end with a brace, track bar and new pitman.
I wanted it done right and no hassles about what may or may not be right or wrong with the front end. Don't like dealing with dealers. The first dealer I went to was trying to tell me the ball joints were still "in spec." What a load of rubbish they throw at you sometimes.
