Truck Wont Start
Old Nov 26, 2009 | 07:05 AM
dodgeman5902's Avatar
Truck Wont Start
Hey Everyone,
My truck has stopped running, it will turn over but will not start.
My last post I was told to try and check the fuel pressure. My question is how do I do this with out a guage kit or can it be done without one?
I checked out the local auto parts stores here and no one has a guage kit for a diesel motor.
Thanks
Old Nov 26, 2009 | 07:51 AM
MikeyB's Avatar
I assume you're wanting rail pressure and not lift pump pressure?
For rail pressure the DRB3 scan tool will be needed, or a rail pressure gauge from Quadzilla or DiPricol.
Troubleshooting purposes remove any external performance boxes to rule them out first.
MikeyB
Old Nov 26, 2009 | 10:13 AM
Thanks MikeyB,
Can I get a DRB3 scan tool from any auto parts store?
Old Nov 26, 2009 | 10:31 AM
mishkaya's Avatar
Originally Posted by dodgeman5902
Thanks MikeyB,
Nope. It's a Chrysler thing, and some independent mechanics have them as well. Not likely the type of tool you would be able to borrow though.
Old Nov 26, 2009 | 11:24 AM
Lil Dog's Avatar
I'm thinking "they" want you to test fuel pressure from the lift pump at the tank to the engine. This needs only about a 30 psi gauge and a fitting to get to the fuel filter canister. This might require a tapped banjo bolt or similar to fit into the lines to/from the filter/pump.
Secondly, drain the filter like you would for a filter change and cycle the key to see if you can get the lift pump to fill the canister. If not, you have found your problem.
Old Nov 26, 2009 | 01:06 PM
rich's Avatar
nickel says injectors hard to start or no start on 03 is a 95% or more injector issue. been there done that
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
doodah
Dec 15, 2002 05:03 AM
Desert Diesel
Dec 5, 2002 08:53 PM
