Tried the cardboard winter front solution today...
Old Dec 15, 2008 | 06:12 PM
  #31
cbrahs's Avatar
I do the redneck cardboard trick too. i put mine between the intercooler and radiator so the intercooler gets the cold air. i have to cut a 18" square hole in mine or she gets too warm.
Old Dec 15, 2008 | 07:01 PM
  #32
b56tc's Avatar
OK, my Mopar winter front just arrived
I always envisioned that it fit between the rad and intercooler - but it appears to go over the whole deal, transmission exchanger, etc - right against the forward most exchanger, with the adjustable baffles in the center.
Although we want to limit icy air to the radiator - I'm assuming it's no problem that all the exchangers are blocked? I guess Mopar would not produce it if it were a problem -
Am I seeing this right?
Old Dec 15, 2008 | 09:17 PM
  #33
hivoltage's Avatar
Won't hurt anything, I'd start with the center open, and experiment with it in order to obtain the desired temps.
Old Dec 16, 2008 | 05:54 PM
  #34
DBLR's Avatar
The Mopar winter front was the best money I every spent on my truck.
Old Dec 16, 2008 | 06:16 PM
  #35
Gunrunner's Avatar
"I don't know how long the electric motor could run uner those conditions and I wouldn't want to experiment. "
Didn't think there was an electric motor on the fan?
Old Dec 16, 2008 | 06:18 PM
  #36
cLAYH's Avatar
Originally Posted by klx650a2
^^^You'll want some air through the intercooler. To remove the fan, an air chisel works wonders. Just remember, its a reverse thread...
Since this is a third gen thread I should point out that 3rd gen fans are regular thread.
I got screwed up big time on this when changing my engine and ended up breaking my fan blade.
Old Dec 16, 2008 | 06:49 PM
  #37
MikeyT's Avatar
I wondered about that when I stuck my cardboard in and noticed that I have a belt-driven fan. Must be a different year?
Old Dec 16, 2008 | 06:54 PM
  #38
92'1stGen's Avatar
None of the 3rd gens have an electric fan, there all belt driven.
Old Dec 16, 2008 | 06:57 PM
  #39
louielouie's Avatar
I just cut out a 26"x32" section of peg board (1/8" holes on 1" centers) with a 6" x 6" hole centered 14" from the top - roughly inline with the fan clutch and slid it down right in front of the radiator. I laced some 0.080" weed-eater line thru the 2nd row of holes at the top and around the cable that fastens to the top of the radiator. The bottom rests on the two cooler lines. Fairly quick and there will always be some air passing thru. I'll make another one and water-proof it for later.
I'll have to try this for my d/d, too.
Old Dec 16, 2008 | 07:51 PM
  #40
wyododge's Avatar
Originally Posted by Festus
There are inserts for our trucks. Look in my gallery. The manufacturer name escapes me right now though.
I opted to purchase the Dodge winter front when the deal surfaced in front of me. If it wasn't a deal, I'd probably be doing the cardboard thing.
Where did you get your winter front from?
Old Dec 16, 2008 | 08:54 PM
  #41
92'1stGen's Avatar
Dodge dealer, it's a mopar part, but I don't think they make one to fit an 02 though.
Old Dec 16, 2008 | 09:52 PM
  #42
Festus's Avatar
^^^^^^^^^^^^^^^^^ What he said.
They may very not not "make" one for an '02 specifically, but I could have probably made it work on my '98 without too much stress - They didn't change too much in those 4 years. Worth checking out.
Tedonlin150
46
Nov 21, 2011 10:45 AM
BC847
Nov 29, 2008 12:05 PM
sallyman1
31
Feb 2, 2008 09:38 PM
Toto
23
Feb 14, 2005 11:37 AM
dodgedude361
14
Dec 10, 2003 10:15 PM
