towing lifted pics
Old Mar 25, 2009 | 04:00 PM
  #46
IsItFast's Avatar
with larger size tires you get sidewall flex
So what you are saying is that the stock tires are the absolutely best tires to not get flex? I find that hard to believe. A lot of guys on here are putting larger tires on there trucks that have LESS sidewall (due to wheel increase in size) and have just as high or higher load rating than the stock tires do. I guess all those engineers that design the big rigs must be idiots since every 18 wheeler on the road runs at least 36 inch tires. And how much do they tow again "unsafely"?.....
As for me, my tires are about 37 inches tall and mine runs better at 70-75 because I am cranking lower RPM's. If it does need to downshift, I don't need to wait for the truck to slow down to 63 mph before it will downshift. This works better for ME.
Old Mar 25, 2009 | 04:04 PM
  #47
NDanecker's Avatar
Getting back to towing with a lifted truck.
I towed with my truck before I added the lift kit.
I towed with my truck after adding 4" Superlift, 35" tires and new rims.
I towed with my truck after removing the 4" lift kit and tires putting it back to stock (because it sucked while towing).
I towed with my truck after doing the dually conversion.
Bottomline -- there is nothing like an unlifted dually with G-rated 19.5 tires (stock diameter) for towing especially when close to, at and above 26k# GCVW.
Old Mar 25, 2009 | 04:09 PM
  #48
IsItFast's Avatar
Well I think a dually is a night and day difference from single rear wheel. Factory or lifted.
Old Mar 25, 2009 | 04:11 PM
  #49
mcolectd's Avatar
Originally Posted by NDanecker
I guess I’m playing both sides of the fence here. I like lifted trucks so therefore I like aftermarket parts. There are some that are junk and some WILL improve the overall performance of a vehicle. I am not disputing that. However, improperly mixing aftermarket parts can give you a truck WORSE in performance and possible an unsafe truck depending how you use it. An unsafe truck is where a lawyer can get you…if found to be at fault in an accident or injury. I personally despise lawyers. They are on the bottom of the food chain in my book. But like flies and mosquitoes they serve a purpose.
For example. This thread is about towing with lifted trucks. Well….lifted trucks usually come with larger diameter tires. When our trucks were designed an engineer took the GVW and designed a caliper with sufficient clamping force and a rotor with the proper diameter and surface area to stop the truck within a certain ‘acceptable’ distance. They also offer a maximum towing capacity mostly dictated by the ability of stopping this added mass within a safe distance. I know…other factors come into play like hitch capacity etc. but those can be bumped up to meet a specific target towing capacity.
Now upgrading nothing more than tire size you have effecting increased the torque created by the weight of the vehicle moving forward turning the 4 tires. To stop the vehicle you’ll have to overcome this HIGHER torque with the brakes. Well…since the brakes haven’t been upgraded (and almost no one upgrades their brakes when doing a lift kit) you have lowered your stopping ability and INCREASED your stopping distance. I know there are other variables like difference in coefficient of friction between tires and roadway by using a different width or style tire, but those can be almost neglected here. The bottom line is the increased distance to stop the vehicle is X distance MORE than stock. Add a 10k# trailer with poor trailer brakes and....well....I hope you see my point.
A lawyer…with this information….can use this in court saying if the defendant hadn’t modified the vehicle from its original design the vehicle could have been stopped in time to avoid my client and/or even avoided the accident by turning sharply if his CG wasn’t so high. Blah Blah Blah….
Lawyers have field days with STOCK trucks that were either improperly designed at the factory to meet certain criteria. Remember the Suzuki Samurai that tips over? The rear tire blowing up on Ford Explorers? Imagine what they could do with a modified truck!?!?!?!?
I read there was a guy who was towing a large trailer. He was over this GVW by just a few hundred pounds. He was found guilty of vehicular manslaughter and doing time for killing a women who cut in front of her on the highway all because he was over his GCVWR. If this story is true…who knows I read it on the internet 3rd person.
My point is use common sense, be careful and DON”T BELIEVE EVERYTHING these manufacturers say that their product can do for us. They are out for one thing – increased sales & revenue. Most even come with disclaimers about safety and warranty. Why do you think that??? When you modify a stock truck you not only become your own warranty station you also become your own legal advice station.
What was this thread about again!?!?!?
Uh i'm pretty sure it was about pictures of lifted trucks towing and got hijacked pretty bad by the lifted truck *****. And on the aftermarket parts thing, nobody said that all aftermarket parts were better than factory. But I don't care what you say, oem manufacturers cut corners to save money. That is why we have aftermarket products... to make our trucks better than they already are, and increase what they can do, and there are tons of aftermarket parts that make our trucks ten times better than stock. Finding out what works for your particular needs comes with experimenting, researching, and experience. And also, with a wider footprint my truck doesn't just FEEL like it tows better, it does tow better. You can't tell me that a wider tire with the same E rating and 10 ply sidewall isn't more stable than a skinnier tire...that doesn't even make since. I don't care what kind of degree any one has in engineering, or science or whatever, designers have flaws. And figuring out what works comes with real world experience, and I'm saying my truck DOES tow better the way I have it set up. Does a truck with a 10" lift and 40s tow as good as stock....hell no, but some, not all setups are much better. But its to each his own though. Just my 2 pennies. Nice truck Kenny, and I bet it pulls good
Old Mar 25, 2009 | 04:15 PM
  #50
mcolectd's Avatar
For sure. And I think lift is going to effect the way the truck handles too. But I disagree on all the tire arguments. I think with bigger, wider tires, a truck pulls and handles better, and feels safer. I do agree though, that too much lift is going to affect the way a truck handles pulling, especially heavy loads. But its all in how your truck is set up
  #51
NDanecker's Avatar
Use some common sense and don't take a statement, generalize it, and try to apply it to another scenario.
Those 22.5 tires probably have more steel in them then a small Honda! Of course they won't flex as much as a stock 17" E rated tire. Geeze......
I was referring to a stock 17" tire going from 30" OD to the 35" OD which is designed NOT for towing but for increased traction, foot print, etc. When I shopped for 35" tires after doing my lift I had a hard time finding a tire with equal load rating as my stock E rated tires. I ended up going with a 20" rim and 35" tires which had around the same load rating ----- and it flexed like silly putty when I loaded them up to their max rating. You load up your 22.5 or my current 19.5 to their rated capacity and I'm sure they don't flex nearly as much as the 'off road' or all terrain tires like the BFG All-Terrains people commonly use from the Hummer (which I also had and they sucked for towing).
Old Mar 25, 2009 | 04:21 PM
  #52
IsItFast's Avatar
Isn't that what every person is doing on here? Isn't that how the "I'm right and you're wrong" argument works on forums?
I'm just saying because the tire/wheel combo you chose didn't work doesn't mean others won't work either. You yourself are generalizing that because of your bad experience that EVERYONE else is going to have the same issues. And that apparently isn't the case as several people on here have shown.
Old Mar 25, 2009 | 04:22 PM
  #53
NDanecker's Avatar
Ok...I'll try to keep this my last post on this.
Sorry for high jacking this thread. I was just trying to share my experience with both lifted and unlifted trucks when towing, and maybe give some advice to people who are on the fence if they should lift their truck if they tow.
I agree...to each their own. Again, I love lifted trucks. Personally, I just don't think they are better when towing then a stock truck. Can they tow....sure but in my opinion just not better. But everyone has a different BUTT METER to measure if 1 way is better then the next....and that makes the world go round!!!
Old Mar 25, 2009 | 04:25 PM
  #54
mcolectd's Avatar
[QUOTE=clemson725;2430803]Well if you want to dispute the laws of physics then go ahead. Maybe centuries of engineers and physicists have been wrong. Keep in mind that these are the same guys that design your trucks. Sometimes "feel" and "reality" aren't the same.
And sometimes what's goin on on the computer screen and what looks good isn't the same as reality
Old Mar 25, 2009 | 04:27 PM
  #55
mcolectd's Avatar
Good points. Everybody is going to like something else. As long as you find what you like and what works for you, then thats all that matters
Old Mar 25, 2009 | 04:32 PM
  #56
NDanecker's Avatar
Originally Posted by Kenny D
im not sure on the weight im still checking on things i was gonna run 2 or 3 8 lug oil baths and convert to a goosneck or perhaps a dualy tandome set up not sure yet
Love those semi wheels
Try to stay with only 2 axles and not 3. Its real tuff on the tires/rims/bearings when doing a 90 degree turn with a gooseneck loaded with 3 axles. One guy I knew kept a bag of sand with him when he needed to turn on a dime in a parking lot. He'd throw down the sand to let the front and rear tires slide around the middle axle.
Yea those semi tires are serious shoes!!!
Old Mar 25, 2009 | 05:41 PM
  #57
clemson725's Avatar
actually the guy that started the thread just said that aftermarket parts were better than factory.
anyway this thread is becoming quite amusing. How do you figure someone says that towing with a 40 inch tire cant tow better than a 31 inch tire, but a 35 inch tire can. thats just amazing. Anyway, wait till those 35 inchers wear out and see if you can keep it in the road. but then again, i'm just one of those lowly engineers so what do i know?
I guess some of you guys are right. What i cant figure is that if bigger tires and lifted have more stability, why doesnt nascar lift the cars and put 35 12.50s on? hmmm......
to the author of this thread, i checked out your pictures. Man, if you pulled that ridiculously heavy load down the street i cant believe you didnt get pulled over by the highway patrol. your front wheels are cambered in like A BUNCH because its so light on the front end. say goodbye to front brakes helping you stop. Some people need to realize that you arent driving a big rig despite wanting to keep your mirrors folded out and putting stacks on the truck.
as for the real big rigs with the tall tires..........imagine putting tons and tons of pressure on a 30 inch tire while going 70mph.... Heat kills. plus, you're taking 4 or 6 10 ply rated tires on your dodge compared to 10 14+ ply rated tires on a big rig with air bags and a 5th wheel hitch that centers the weight over all 6 back tires. Its night and day.
Old Mar 25, 2009 | 05:47 PM
  #58
Kenny D's Avatar
cool thank you i have towed 3 axle trailer but it wasnt my truck or trailer and i didnt really pay atention haha
and for all you OEM is the best people and warenty people you can now buy LIFTED TRUCKS at the dealer brand new under warrenty with aftermarket lifts ANY COMMENTS ON THAT ?????
wow this thread got way off track but i gues a little talking is alrite
and my original point wanst that they tow better just that they can do what a stocker can do and look cooler doing it and really did want some pics i know theres guys on 40s on here trowing all the time
aaah i love the DTR
Old Mar 25, 2009 | 06:53 PM
  #59
Fisherguy's Avatar
Wow, this is like Clem's tire thread, he had to tell us how smart he was in that one too.
Don't waste your time arguing with him.
If he can't figure how a modded truck with 35" tires that has 450 hp on the dyno can tow better than his 100% stock truck what's the point?
Old Mar 25, 2009 | 07:26 PM
  #60
mcolectd's Avatar
Ya its not worth it. We'll just let him keep his stocker, and we'll keep towing with our "unsafe" lifted trucks on 35" tires...OMG thats crazy, who would do that? BTW, nascar is a lot different than our trucks and way different than what we're talking about in this thread. Do you see them towing anything? And I dont leave my mirrors out cause I think I'm a big rig, I do it cause I can see better with them like that, and I think it looks better. Makes your truck look a lot stouter. Why did dodge make em like that if you're not supposed to use them? I always see people towing a big horse trailer or camper with their mirrors in Makes no sense to me, but whatever
