Tow Hook Question...
My truck didn't come with tow hooks and I want to install them. I know the kit is available from Mopar, and I have found the hooks and brackets on eBay as well. My question is: Do I need the brackets? I havn't had a chance to look at a truck with hooks installed from the factory. I see just hooks (no brackets) being sold as well. My bumber bracket has four holes which I believe match those of the hooks. Are the brackets just additional for strength as I suspect, or did anyone's truck come with hooks mounted on the bumper brackets from the factory? Maybe someone who has installed them could email me a .pdf of the directions?? I did search some threads before I asked this, but couldn't find my answer.
Seeing some directions would be great. Email is ajpulley@hotmail.com. Just for curiosity, what are you asking for the hooks and brackets?
Originally Posted by guzzirider
Pretty straigt fwd install you will need a pry bar, reverse the nut plate took me 1.5 Hrs on a chilly day
You have to take the bumber off then lossen the intercoller. Then remove the bracket that holds the bumber to the fram rail. You then add brackets to the fram rail bracket and put the hooks on them and then bolt and torque everything back down. Its easier then it sounds and the kit comes with great directions with drawn pictures.
What brackets? I recently removed the tow hooks from my 2005 2500 because I don't like the look and the only pieces which come off are the hooks and the nuts and bolts to attach them.
