Taller TIRES
Old 01-31-2008, 02:53 PM
  #31
schloe's Avatar
It will be exactly the same width. The width of 285 mm is 11.2 inches. The height will be 285 mm *.75*2, or 16.8 inches, + 17 inch rim = 33.8 inches tall.
Old 01-31-2008, 10:05 PM
  #32
Texan1983's Avatar
Originally Posted by Tee
The 285/75 should be the same width as a 285/70, just a little taller.
acually taller and a little narrower.
what are the RPM's on you manual guys at 70 mph?
Old 01-31-2008, 10:30 PM
  #33
nvr-enuf's Avatar
taller tires
If you are willing to go to 31.8" diameter tires, then the best bet for mpg would be 235 80 17's. I have 265 70 17 on mine and I am willing to bet that if I change to the 235's, I will see a 1, maybe a 2 mpg increase.
Is anyone running this size tire and have you seen an increase in your previous size?
Old 02-01-2008, 06:37 PM
  #34
Festus's Avatar
Every last one of you should get your name in on the list in this thread if you haven't already done so : https://www.dieseltruckresource.com/...d.php?t=183470
Behind your name and location, add in the size you want!
Old 02-01-2008, 08:15 PM
  #35
Tee
Tee's Avatar
I am already there! When will it be going to someone who might actually read it and do something for us?
Old 02-01-2008, 08:58 PM
  #36
Vinceg99's Avatar
Glad to see this post just when im in need of new tires sooner than later.
I also would like a taller tire lower my RPM's a bit more, was debating on 19.5's to get more life out of my tires (my 17's only last me like 8-9 months) but doesnt seem like you get that much more tire life out of them than 17's then with the added cost seems almost like a wash unless you get the 19.5's for free or next to nothing.
Anyone running 19.5's towing? what kind of life do you get out of them by chance?
Old 02-01-2008, 09:28 PM
  #37
Festus's Avatar
I'd like to get a few more names to bolster position on my the rep in my area any........he's still got some bureaucratic responses -- I'd like to send himm a bigger list to open his eyes a bit more.
Old 02-02-2008, 08:20 AM
  #38
levigarrett76's Avatar
ive posted in the toyo list....ive called and emailed every tire company numerous times asking if they plan to make a 255/80 r17 or something similar....when they say know i ask them to please forward the comment, im gonna keep calling them at least once a month!
i know theres a market for these out there!
Old 02-02-2008, 10:10 AM
  #39
Texan1983's Avatar
what are your rpms at 70 mph?
Old 02-02-2008, 11:14 AM
  #40
2250....id like around 2000 or less.
I bought a GV overdrive but returned it because i tow very heavy on occasion and was afraid of blowing it up backing up hills. Im looking into a 3.42 gear swap.
I do alot of interstate driving
Old 02-03-2008, 03:22 PM
  #41
nvr-enuf's Avatar
Are you sure you have 3:73s or do you have 4:11s? I see that you have a newer truck than mine but I run slightly less than 2000 at 70 mph and I have 3:73s.
I have a calculator for tires as well as rear end ratio if you want to play with it to see what changes will affect your rpm as a function of tire size / rear end gear. The calculator uses the tire spec criteria, 245 / 75/ 17, so you can look up sizes on tirerack of different sizes to see what the effects are.
I am considering 235 / 80 / 17 for my next set. Is anyone running these on a non dually truck and if so, did you see an increase in mpg versus the 265s?
Thanks
Scott
Old 02-04-2008, 06:02 AM
  #42
Thanks
Scott
Yes i have 3.73's, i have a shallower OD ratio than you(.79) rather than your .72?
I made my own little chart at work one day. I use a formula to get rpm etc.
mph/tire size * 336 *Final gear ratio
example....
my final ratio is 3.73*.79=2.95
70/31.2*336*2.95=2224rpm @ 70 mph
Old 02-04-2008, 07:33 AM
  #43
Neight's Avatar
I have decided to go 19.5's I can get a real good deal on the tires. I wish the **** tire companies would listen..
Old 02-04-2008, 08:44 AM
  #44
will say 265 19.5" tires stick out past the fenders in the rear?
Old 02-05-2008, 06:36 AM
  #45
Neight's Avatar
anyone ran these http://www.michelintruck.com/micheli...read=XDE%20M/S
Quick Reply: Taller TIRES
