Tail Light Assembly removal
My owner's manual states to remove the two screws and pull the assembly straight out. Well, I remove the screws, and pull pretty darn hard, and the assembly does not come out. Something else is holding it, what is it?
Thanks
Thanks
I thought that same thing when I had to replace a bulb. After a little twisting as I pulled, it came right out. There are a couple posts with a ball end on them that fit into a rubber hole and that is why it is hard to remove. Get a good grip and pull, you'll be fine.
Thanks for the replies. I did notice that with the screws removed, the assembly would swing out as if on hinges, but I was following the excellent instructions in the manual, which said to pull straight out in order to avoid breaking the alignment pins.
I'll give it another try when I get home this evening.
Those pins have a tyt(Sorry mods, I didn't mean to curse) on the end that go into a rubber hole. It's a tight fit and that's why it is hard to pull the assembly out. There is no hinge...
1. Pop the hood and use the pliers to disconnect the negative battery (-) cable
2. Fully open the tailgate. Locate the 2 torx screws on each side of the bed.
3. Use the torx screwdriver to remove the screws. Keep them in a safe place for later installation.
4. Pull the tail light assembly
Roperteacher
Oct 3, 2011 09:45 PM
MattRuskow
Dec 15, 2010 08:01 AM
Viperdew
Jan 2, 2009 12:13 AM
TGriffith
Dec 8, 2006 10:34 AM
