Strange intermittent noise from front end
The Ram in my sig has started with an unusual noise in the front end. It has done it 3 times. Once pulling out of a parking lot onto a road, once pulling into my driveway and once going down t he highway. All three involved a "quick" dip/bump. The noise sounds like a large out of tune guitar string. The first time it happened I thought I hit something that might have ricochet off of the running boards the way it resonated through the truck. Sounds like it is on the drivers side. Speed bumps do not reproduce the sound. Pot holes doe not reproduce the sound. Any ideas? TIA.
I dont know about the steering stops as it has made the sound going in a straight line (highway). The coil spring shifting? Makes sense, but I cant reproduce it on a harsh bump (say a speed bump or something like that). Both times it happened in a turn it was a right turn, though not sharp. And I cant remember if it was on compression or rebound of the spring. It catches me off guard since it is so intermittent. I'll look in the spring cups if I can for any shiny spots.
I have the same sounds... Im taking mine to the dealer... it sounds just as you described... I can replicate it by having my front pass. tire in a dip and rocking the truck on the pass side running board. Seems to be indeed coming from the front coils, the bucket area... there is also a sharp pulse that goes thru my coil associated with the sound... I think it may be the spring shifting as posted above. it sounds so annoying, a new truck shouldnt sound like that. I will yield the results of the dealer after this weekend.
noise
I think I had the same noise coming from my 04. I found on the back of one of my nuts on the steering linkage not sure about the real name of the part. It is a catch on the nut to keep it from spinning well it had spun around and was hitting the spring and it was making quite the noise. loosned it up put it back the way it should have been noise went away. You might check that. it was on the driver side real close to the bottom side of the spring.
Mike
Thanks for the replys guys. When I get time I think I'm going to crawl under the truck and tap on some suspension parts with a hammer to see if I can duplicate the sound at least. Let us know what the dealer days 2-stroke.
Don't know if this will help, but: https://www.dieseltruckresource.com/...ad.php?t=80095
I called my dealer and talked to them... it seems the sway bar bushings were worn... they have to order them in and install, so I cant swear its fixed... but its logical - Check yours out... that might be your problem aswell!
tell me about it... although i have 40k on my truck... i never really heard the sound till about 20k. Thats the exact sound... it used to happen to me over a tall speed bump, straight on hit around 10 mph. entering my driveway at a 45* angle with the pass front hitting in the dip of the entrance... and when driving over ruts in a field, etc. I knew something was up... but I didnt think about the sway bar bushings... the replacements are on order, and should be here today or tom. After they are installed I will relay my findings, hopefully to assist you in curing your truck of the "thong"
Don't know if this is connected, but just recently my truck has started to make a strange sound from the front end. I can only hear it when I drive over particularly rough cobblestone roads. It is a deepish, hollow sort of rattling sound. It's not very loud and I can't hear it when driving next to a wall with the windows down. Never thought of the springs until it was mentioned on this thread, but suppose it could be a spring kid of noise. In a few days will climb under, jack it up if necessary and check everything.
