Step on accelerator - Nada
Old Jun 7, 2005 | 10:44 AM
MrBilly's Avatar
I have a 2003 dually 4x4 with stick. On three occassions over the past 7 months right after starting the Cummins engine, I put it into gear and step on the accelerator nothing happens; the engine does not speed up and the truck doesn't take off. If I pump the accelerator two or three times, something happens and off I go. It has always been right after start up, doesn't seem to make any difference if warm or cold engine. Never happens more than once in a single day, and the days are months apart. Any thoughts?
Thanks.
Mr. Billy
Old Jun 7, 2005 | 11:40 AM
MikeyB's Avatar
Most likely the APPS (Accelerator Position Sensor) is going south. It can be found under the drivers side battery tray. Try reseating the connector several times (to wipe the contacts) and drive it before replacing the module.
MikeyB
Old Jun 7, 2005 | 08:25 PM
moterhead's Avatar
As MikeyB suggested, pop the connector in and out a few times then squeeze some dielectric grease into the connector. That will help stop future corrosion.
Old Jun 7, 2005 | 10:02 PM
Badunit's Avatar
Check out this TSB:
http://dodgeram.info/tsb/2003/18-027-03.htm
Old Jun 9, 2005 | 10:31 AM
billyrae's Avatar
What a great site! Advice like that will save you $$$ and time.
SOhappy
May 7, 2012 10:43 AM
Dodgezilla
Dec 18, 2007 09:48 PM
usernames_taken
Apr 3, 2007 05:08 PM
bkeence
Nov 17, 2004 09:49 PM
