Steering problem
Old Feb 17, 2011 | 11:54 PM
braap736's Avatar
Steering problem
When I'm taking any corner at 45mph or faster the steering wheel wanders back and forth which makes the truck weave back and forth, back and forth all the way through the corner
Old Feb 17, 2011 | 11:57 PM
braap736's Avatar
The front end is tight and alignment is good,what could cause this?
Old Feb 18, 2011 | 01:06 PM
El Borrego's Avatar
How's the fluid in the power steering? Sounds more like the power steering pump. Could be the valve in the pump not holding fluid pressure when in the turn.
Old Feb 18, 2011 | 04:44 PM
braap736's Avatar
That makes since ill check it
Old Feb 19, 2011 | 08:26 AM
braap736's Avatar
The fluid was at the bottom of the stick, below the add line. I haven't drove around a high speed corner yet to see if it made a difference
Old Feb 19, 2011 | 08:29 AM
greasy1's Avatar
A bad ujoint in front axle will make it do it too!
Old Feb 19, 2011 | 09:12 AM
braap736's Avatar
Are you talking about the turn joints?
Old Feb 19, 2011 | 05:21 PM
greasy1's Avatar
The ones on the front axle shaft
Old Feb 19, 2011 | 07:37 PM
Sur5er's Avatar
You are in 2WD, right? Next would be axle U joints or steering shock, followed by a really bad tire.
Old Feb 19, 2011 | 07:50 PM
braap736's Avatar
I just put new tires on it with no difference. Just got back from driving it around some curves and its noticeably better but still there, this is after filling the p/s fluid up. Although I used regular p/s fluid and I think it takes atf +4. Will this hurt anything?
Old Feb 19, 2011 | 07:52 PM
braap736's Avatar
So I'm thinking that the pump is going bad since adding fluid there helped, maybe it being ran low messed it up
Old Feb 20, 2011 | 07:40 AM
Sur5er's Avatar
PS uses ATF+4. Even if you change the pump. you will still have to flush the system
Old Feb 20, 2011 | 09:41 PM
braap736's Avatar
Alright thanks. Are these pumps fairly easy to change, judging by the reservoir its down there quite a ways
Old Feb 21, 2011 | 04:36 AM
papaduck's Avatar
Before you change the pump, jack up the front end, one side at a time, and with the steering wheel turned to one side rotate the wheel by hand. If you have a axel u-joint that is locked up you will be able to feel it.
Old Feb 21, 2011 | 09:03 AM
braap736's Avatar
Ok ill try that, also today I noticed its gotten even better so I'm gunna flush the fluid with atf+4 and see if it completely goes away
LanceK
13
Jul 14, 2006 08:08 PM
ocsurf16
Mar 13, 2006 09:24 PM
unioncreek
Jun 29, 2005 02:00 PM
OHFarmboy
Feb 25, 2005 11:30 AM
Jun 5, 2003 09:27 PM
