Starting ?
Starting ?
OK, I have been noticing that when the temp drops into the lower 50s and 40s, my truck (which is garaged) starts but runs ROUGH and throws a little white smoke out for about 30 seconds.
I DID the TSB re-flash.
It only has 3K
It runs fine otherwise
My oil level did NOT increase
Is this NORMAL or could it be a sign of an injector leaking and going bad???
It only has 3K
I remember my truck doing that (white smoke on start up) winter before last. It finally just went away on it's own with no problems.
Clogged injector maybe? Maybe try running some biodiesel in it to clean it out. Also, after the truck is warmed up...go run it hard and get your EGTs pretty high to help blow it out.
fourthandgoal
88
Dec 27, 2011 05:39 AM
abc4yew
Mar 15, 2007 11:55 PM
