squeky door panels....
Old Mar 9, 2008 | 05:40 PM
one54ton's Avatar
...are very annoying! anyone else have this problem? a way to fix it?
Old Mar 9, 2008 | 08:29 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
Happens to all of my trucks. Either pull the whole panel off or like I do, pry the edges back enough and slide a little piece of sandpaper on the plastic side and scuff it a little. Works longer than silicone or other lubricants. Usually goes away completely. Best part is that I find myself always asking, am I the only one hearing that!?
Chris
Old Mar 9, 2008 | 11:08 PM
one54ton's Avatar
nice tip...what grit would you prefer?
Old Mar 10, 2008 | 04:13 PM
dale29's Avatar
mine was the mirror mount bolt inside the door near the hinges. I tightened it up and no more squeek!
Old Mar 10, 2008 | 04:34 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
Whatever's handy. The objective is to scuff it and not leave it smooth.
Chris
Old Mar 10, 2008 | 07:59 PM
Diggie's Avatar
You can also cut a piece off of a tire tube, and insert it between the door and the panel. Tuck it away, and no one will know it's there.
Old Mar 11, 2008 | 08:43 AM
lniemeyer2's Avatar
I used electrical tape anywhere the panel made contact.
Old Mar 11, 2008 | 09:11 AM
kingofdodge7131's Avatar
I actually had the problem where ther mirrors attact to the door. The top back would... flutter against the glass? I tightened that thing and nothing seemed to fix it. Only thing that worked was just barly tapping the window down. Finally i had to take the mirror off and put some washers between the mirror and the door. Only thing that ever worked for me. Very annoying
So is the cross wind noise in these trucks. Dunno why the door seperates so easy. mine makes me mad. My bro has an 02 though and OMG his is terrible.
Old Mar 13, 2008 | 09:54 PM
plessm's Avatar
My passenger front door does it bad. It's the door panel at the bottom. It does it really bad when the truck is cold, or winter time. When it's hot during the summer, no squeaks. I keep meaning to take it off and fix it, but I like the sandpaper trick better.
Old Mar 14, 2008 | 08:30 PM
dtrkstan's Avatar
Black plastic tape folded over and slide in tween the squeaky spot, been 48000 miles and no problem
Dieselcamper
Sep 1, 2005 03:13 PM
Mr. Plaine
Oct 5, 2004 11:10 AM
ClawHammer
Jun 21, 2004 05:41 PM
kstrongsyj
Oct 25, 2003 08:07 AM
