Squeaky back window.
I have a slider rear window and it's ticking / squeaking. If I open and close it a few times the noise stops but starts up again after a few miles. Anyone experience anything like this? It's freakin' annoying.....
Yep, mine will do the same thing but only when it is 100% closed tight. It's the electric version, so I barely bump the switch to open it and the squeaking stops. I suppose that whatever two surfaces were together and causing the squeak are now not touching.
Maybe give that a try?
You've got some dirt, dust or grit in the track or lock somewhere...mine did the same thing. After repeated cleaning and not getting it solved longer than a week, I ran a bar of soap splinter along the tracks and the lock and haven't had a problem since. I suppose a candle would work as well, but i enjoy the smell of Irish Spring
My window is a manual slider. I slopped some silicon grease into the tracks (top and bottom) and it helped but there was still some squeaking. Then I cycled the window back and forth about 10 -15 times and now there's no squeaking or ticking. Nice and quiet so far.........
koondawg
Nov 21, 2012 04:35 PM
raven392003
Oct 29, 2007 11:39 AM
Ridiculous
Mar 15, 2006 09:26 AM
rockittboy
Feb 2, 2006 04:58 PM
JoshPeters
Apr 3, 2005 08:13 AM
