Speedo Recal Txk Tx
So I gots me some new shoes on the goat. Got some Nitto 285/17/E. Now My speedo needs a do over. Yes the dealer can do it but,, I don't like going to the dealer they would probably want money. Are there any volunteers in my area with a Smarty or something that can hook my up?
I believe the Smarty ABS is vin locked. I have the 285/70 R17 hankook A/T a 32.7 inch tire. Smarty adjusted with 55PSI in rear to 32.00. Checked it with a radar sign. I am very close. started at 32.50 on the Smarty.
good luck
good luck
FYI - my dealer did my recal for $50. I'm not sure if you (having an '06) can have the dealer do it anyway - someone should chime in and verify that shortly. I think they can only go up to the 285/70/17's for your model year.
BUT -
I think I saw a thread around here a while back saying there's a Snap-On tools fix for this - maybe you could find a Snap-On distributor that would do it for cheap for you?
ON EDIT -
I found the thread - https://www.dieseltruckresource.com/...t=snapon+tires
BUT -
ON EDIT -
They just have to go in their with their programmer, select ABS settings and dial in the tire size. How does that take an hour? If you don't have a scanner of your own or a programmer to do it by your self your only option may be the dealer. At least call a different dealer and see if they will actually tell you the truth.
I say 3 minutes tops.....I watched them recal mine and they charged me zero! Just get them to come up and check for codes..sweet talk the tech into changing it. I also had them change my interior/exterior light timings.
booman70
Sep 14, 2006 04:25 PM
Dodgezilla
Dec 12, 2005 10:28 AM
