Reverse Lights quit working
I have a 2004 with a standard and I believe my reverse light switch in my transmission (or however it is set up) quite working. For a little while I could giggle my stick and the reverse lights would come on. Now they are completely out and the fuse is good. Can anybody give me any help?
Most likely it's the reverse switch on the transmission. Most autoparts stores can get it (or even have it in stock). Just tell them it's for a NV5600.
If I remembered correctly it's located on the passenger side of the transmission.
MikeyB
MikeyB
Reverse Light Switch
My reverse lights went out also,it was the switch.I got mine at:
www.quad4x4.com
www.quad4x4.com
I wanted to post the part numberbut the post went up on its own.Her is the number #qu10132 the cost was 24.98
I hope this helps you.The switch is on the passenger side of the trans.Unplug the switch than unscrew it from trans.Screw in new switch, plug the plug in and you are good to go.Trust me if I can do this anyone can.
I was experiencing the same problems. I took the plug out and unplugged the driving lights in my bumper and completed the circuit with the switch plug, it worked fine. So I figured it wasn't in tight enough, nope not the problem, unplugged it again and noticed the plastic piece turned inside the nut, so I turned it expecting it to get tighter, no, but it did have a place that felt like it slightly dropped into (had a different feel at one spot), plugged it back in and it was good to go.
Darrin F.
Dec 10, 2010 07:18 PM
JKE
Dec 23, 2003 08:51 PM
