Reserve warning update....
Old Jul 2, 2003 | 10:46 AM
nicksort's Avatar
Well this is an update on what happened.<br><br>I finally had made it to the 1/8 mark on the fuel gauge and I continued to put an extra 30 miles on the truck and the Reserve warning light never activated. I decided to pull into a station for fuel and found a Mobil station nearby. I new that when the dealer had sold me the truck they told me they had filled the tank for me, but I was sure they filled it until the nozzle had clicked off so I decided to do the same and check the numbers.<br>I managed to get 26.2 gal in before the safety shutoff started to click often. I figured this truck is acting the same as the 2001 I had just traded in, 8gal reserve. I decided to see how much more I could fill it if I added a small amount at a time and wait for the foam to settle per your sugestion, before adding more. I got it to fill the neck and it took 32.3 gal. I can safely say that my tank is FULL.<br>I know that with the 26.2 gal I had gotten 18.77 mpg, but I am unsure if this is true, but it should be close. I am happy.<br>After I filled the tank I checked the DTE, and it had registered 529 mi. I have driven 103miles since I filled it and the DTE reading is still at 529mi. My MPG (computer) is steadily rising and is now at 18.1mpg. <br>
Old Jul 2, 2003 | 11:15 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Re:Reserve warning update....
Like it was said before...the manual clearly states that the reserve is approximately 10% of the tank capacity....meaning about 3-1/2 gallons for the 34 tank. In other words...when the needle hits the E you should have about 3-4 gallons left to run on. Don't know why your idiot light didn't come on....but I don't suppose it matters whether it comes on or not.
And just so you know...I believe it's intended to be a &quot;low fuel&quot; light....not a &quot;reserve warning&quot; light. It's only purpose is to let you know that you are nearing a point where you will have to stop and get fuel. I believe the idea is that you will fill up before the needle hits E and your reserve will never be needed. I think the reserve was intended for emergency situations to help prevent drivers from running out of fuel.
Old Jul 2, 2003 | 12:18 PM
crabman's Avatar
Wouldnt want to have a lawsuit because the truck ran out of fuel when the gauge said empty.
Old Jul 2, 2003 | 01:52 PM
Hoss's Avatar
No kidding. : &quot;My truck just died on me while I was driving down the road!!&quot; &gt; &quot;Sir, how much fuel did your fuel gauge show?&quot; &quot;Well....it said it was empty.....BUT STILL!!! IT SHOULDN'T HAVE RUN OUT OF FUEL!!!&quot; &gt; &gt; &gt; &quot;Here's your sign...&quot; :
Old Jul 4, 2003 | 02:44 AM
Old School's Avatar
Well...My dadgummed fuel guage is BUSTED!! &gt; &gt; It worked for the first few tanks...then, I started watching it to see when the binger (chime) comes on after reading these posts, low and behold I always had 7/8 or more in the tank, even after driving 400+ miles. When I refill, the tank goes back to F+ but then hangs at 7/8 &gt;. I suspect the sender and or float mechanism in the tank, since the guage will return to -E when the key is turned to off. I won't get into trouble since I always use the odometer for safety and the guage as a back-up, but I'm still pretty bummed. The Old School Ram will be headed back to the dealer 1st thing Monday morning. I'm curious if any others have had this problem? ???
nicksort
22
Jun 29, 2003 08:58 PM
