Removing rear spacer blocks--any bad effects?
Moterhead is right. I measured the height at the front license plate before and after removing the rear spring spacers. I don't remember now, but I think it went up about 3/8" and the tailgate went down about 2-1/2". I have 140.5" wheelbase. It would be a little different for the LWB.
I recently installed the 2" spacer leveling kit. It seems to me by looking at the truck the front is actually highter than the rear now. Do you guys know if adding a spacer to the rear is possible. If so any body want to sell me a set.
Jamie
Jamie
Sorry guys but everybodys right. Maybe my term was wrong, front end to me meant the front bumper. Which HAS to come up to effect a change in the headlights. It also changes the tolorances between the front fender lip and the tire which is what I was trying to figger out ! RickE your 3/8" is about what I come up with guessing at wheelbase and front overhang THANX
From: Dead Center in the Middle of TN. 20 miles from Jack Daniels, 10 miles from George Dickle and .8 mi from the liquor store at I-24 Exit 114
I would like to do this to my 2WD '03 QC truck. Is there a link to the process? Might save me some time. Thanks, Jim
I have been following this thread hoping for a little more information on the removal of the blocks. I used the search last night and could not find the detailed post telling how it was done. I tried again tonight with no better results.
Is there any spring clamping involved? I am guessing two c-clamps and a few minutes changing them out will swap them. Jim
I will buy one spacer per side from somebody willing to get rid of theirs. If not anyone know If I can order them from DC. I would like to raise my rear just a little. seems to me the 2" leveling kit left my front end higher than the rear. Just noticible.
thanks Jamie
thanks Jamie
Ken Lenger, who posts over on the TDR, has the procedure detailed on his website. Here is the link
http://www.klenger.net/dodge/lowerin...d/slide01.html
Please note that even though the title on Ken's slide show says "4WD", the procedure works fine on 2WD. I did mine.
The only thing I would add to Ken's comments and pictures is to buy four new spring center bolts before you start the job. The factory bolts have round heads. If they spin, you must resort to vice grips to hold 'em. One of mine, naturally the last one, was a bear! Vice grips wouldn't hold it. Had to use a pipe wrench. That one stubborn bolt probably added 50% to the job time for me.
"If you do this, do yourself a big favor, and get new bolts hold the spring pack & spacers together. the factory hardware is junk [no hex head on the bolt] 1/2"NC x 4.5" is what i used if i remember right, with some nyloc nuts on them"...nick leinonen
This was posted earlier in the thread
Thanks for the further assistance guys, Jim
I thought I read it somewhere but thought it was in one of the posts I read when I did the search and could not remember which one.
This was posted by Wetspirit on 1-3-04.
I took out the two lowering blocks on my truck and am glad I did. The truck is almost level and looks a bit better. It's not to hard to do.
Also, if you wanted another bit you could remove the overload leaf under the spring pack (on the 2500's), this is almost an inch thick, but it would reduce your load capacity.
All you have to do is pull a rear wheel while supporting that side of the truck with a jackstand under the spring pack behind the axle. Support the center of the axle (in the middle of the truck) with a floor jack. Put a "C" clamp on the spring pack in front of the axle. Remove the U bolts. Lower the axle with the floor jack about 4 inches. Remove the spring center bolts one at a time and replace with 3 1/2" grade 8 bolts and nuts (loosen both bolts, swing the lifting blocks asside and install the first bolt with Locktight Blue, also grip the round bolt head with a vice grip to remove the nut). Move the plastic centering pin to the overload leaf and jack the axle back up with the floor jack. Use a deep socket to re-install the U bolts. Re-install the wheel and go to the other side.
The new bolts are hex and the existing are small round head, so I was aware of the flat orientation as I tightened them to allow maximum clearance in the axle saddle.
It's quite easy and you could always go back if you wanted.
Wetspirit
Wetspirit
Maccandy,
Thanks for posting my procedure on removing the spacers. This the easiest and best way I can think of to do this. I've put on about 40,000 miles since this mod and I love it.
Wetspirit
Wetspirit
