Regen cycle
Old Oct 11, 2008 | 10:16 PM
whiteeye42's Avatar
Regen cycle
How offen does DPF regen i have about 3000 mile on my truck and it has not gone in to the regen cycle yet
Old Oct 11, 2008 | 11:32 PM
BroncoHound's Avatar
If your truck is stock, it's been in a regen. Usually an active regen is every 400-500 miles though it differs depending on how you drive, your truck setup (transmission, rear gears, cab and bed configuration, tire size, etc), and the loads you pull. You aren't supposed to be able to tell when your truck is going into active regeneration. In the 22000 miles that my DPF was on the truck, i couldn't have told when exactly it went into active regeneration a single time. It did, though. ALOT. So is yours.
Old Oct 12, 2008 | 07:29 AM
Dodgezilla's Avatar
The only way I knew I was regenning was by watching the OH mileage start to drop for no apparent reason. If you never reset your OH then you probably would not see a real difference. I reset mine with each fillup....
whiteeye42
Oct 11, 2008 11:33 PM
Rob Mitch
Aug 5, 2007 01:44 PM
skeeterboy
Aug 3, 2007 06:43 PM
Apache1
Jul 31, 2007 08:05 AM
duckbill
May 4, 2007 07:38 AM
