ratteling from front end
Old Jul 19, 2005 | 10:25 AM
billyrae's Avatar
When I'm on gravel/sand roads I hear a ratteling from the front end. I used to put it off to gas sloshing in the tank. I'm just ideling along at 5mph or so. I'm concerned it's in relation to that ball joint issue. I've had about 4 oil changes at 12000 miles and the dealer always says the joints get lubed. My tires and suspension are all stock. Are my wheels gonna fall off? What should I be checking and torquing down?
Thanks!
Old Jul 19, 2005 | 11:25 AM
Nuttymopar's Avatar
Not sure but one thought would be to jack your frontend up and off the ground and see if you can shake your tires around to see if anything rattles that way. That would at least allow you to check your King Pins to see if they are loose or not.
Old Jul 19, 2005 | 12:58 PM
nickleinonen's Avatar
i almost wish we had kingpins... but we have balljoints..
Old Jul 19, 2005 | 06:40 PM
coalbucket's Avatar
I thought the ball joints was sealed. I only have about 2200 miles on mine and have not looked but did not see any zerks on them.
Old Jul 19, 2005 | 07:47 PM
nor will you find any on them
Old Jul 19, 2005 | 08:08 PM
Original Junior's Avatar
You have to look hard. They're right behind the king pins and in front of the muffler bearings.
Old Jul 19, 2005 | 08:48 PM
RamWheelsBy4's Avatar
Well first you need to get the "gas" out of the tank. I have been under mine about a dozen times looking for the noise/rattle that I can feel and hear. I have jacked it up, pushed and pulled and looked at every bolt and bushing and anything else that might be loose. I cant find it. Sometimes I think it is gone and it was just my imagination, but then its back. If you ever find out what it is please let me know.
Old Jul 20, 2005 | 09:23 PM
Scubasteve's Avatar
If your dealer says the balljoints have been lubed at each oil change he is full of poo poo..
Try the same road while you have some pressure on the brake pedal to rule out calipers or pads flopping around.
Lower shock mounts can sometimes give you that problem.
What i find works good for locating noises is to go out with a friend to a bumpy road and do coast tests, get some speed up flip it in neutral and shut off the engine and make sure there is no one else around..lol
Do this from the driver seat and passenger seat noting which is lounder and you can also stick your head out the window if need be just don't start barking or your buddy may never travel with you again. Also try it from the back seat as some noises do travel and can be very deceiving.
Good Luck
Jason
Old Jul 21, 2005 | 07:06 AM
Nuttymopar's Avatar
I have had my Brother in the back bed while I drive slowly so he can listen.
Old Jul 21, 2005 | 11:21 PM
JAF's Avatar
JAF
Check ALL your u-joints. That was my noise maker.
Old Jul 22, 2005 | 10:36 AM
dezeldog's Avatar
I had a similar noise and it turned out to be the links on the front stabilizer----had 'em replaced and that tokk care of it.
Old Jul 25, 2005 | 03:54 PM
alltimelow1's Avatar
had that same noise for about 40,000 miles now and cant find the cause either - I've given up - let me know if you find anything out
1999blackcloud
Jan 26, 2010 08:52 AM
pred
May 22, 2006 12:56 AM
Gordonville
Apr 18, 2005 09:45 AM
royta
Jul 13, 2004 06:54 PM
