Question on Heater Cycle
Old Nov 10, 2006 | 11:33 PM
JetDoctorX's Avatar
During the post start (After starting) heater grid cycle, my volt meter stays at 12 for the duration, it does not cycle between 12 and 14 like I'm reading about other peoples trucks doing. After the 2-3 minute cycle the volts come up to 14, but shouldn't my volt meter be cycling as well? If so what could be wrong? What tells the heaters to cycle? JD
Old Nov 11, 2006 | 01:30 PM
pet05's Avatar
I believe if it is COLD outside then it will cycle. If it is NOT cold, it does not need to cycle.
Old Nov 11, 2006 | 04:25 PM
JetDoctorX's Avatar
I know that, what is my volt gauge supposed to be doing during the cycle?
Old Nov 11, 2006 | 11:22 PM
pet05's Avatar
It sometimes will cycle down from 14 to 12 but not always. It all depends on how cold.
Old Nov 11, 2006 | 11:38 PM
FMB's Avatar
FMB
If you would take the time to click on "User CP" up above and edit your signature, we would have an idea of what vehicle you are refering to. Thanks,
Old Nov 12, 2006 | 01:34 PM
JetDoctorX's Avatar
Thanx FMB...
Old Nov 12, 2006 | 05:53 PM
FMB's Avatar
FMB
Have you pulled any codes? (Engine stays off... Key to Run, Off, Run, Off, Run... read codes in Odometer... Will be letter P followed by 4 digits... says P-done when done". Post any codes.
Old Nov 12, 2006 | 09:14 PM
JetDoctorX's Avatar
I've got a 1650 code for bus comm. but I don't think it's related. I'm hearing that some of the trucks volt meter will cycle with the grid cycle and some won't. Not too sure what the rhyme or reason is. Wondering exactly what tells the grids to cycle. JDX
Old Nov 12, 2006 | 09:45 PM
Geico266's Avatar
Once you start moving (over 25 MPH) the grid heaters no longer cycle. Are you moving?
Old Nov 12, 2006 | 11:04 PM
JetDoctorX's Avatar
No, after start up. During the 2-3 min. cycle.
Old Nov 13, 2006 | 11:46 AM
GreyTD's Avatar
Jet, mine will stay at 12v also until cycle is over. read some where that the ecm controls alternator charging, so to protect it from over current draw (grid heater draws about 200amps) ecm shuts down alternator. On others it may not or cycles it on and off. someone will correct me if wrong.
Diesel Rover
Jan 4, 2008 03:48 PM
drydocked
14
Nov 10, 2007 12:45 PM
estesbubba
Oct 13, 2006 11:26 PM
Silverjay
Jan 30, 2006 02:18 PM
jfpointer
19
Nov 6, 2005 11:41 PM
