question on a couple of companion codes?
Old Sep 21, 2004 | 11:00 PM
Barrett_Fodder's Avatar
Unhappy question on a couple of companion codes?
I was messing around with the truck today and decided to pull the hours and check for codes. Got 480 hours and 3 codes...arggg
As far as I can tell these are companion codes but I dont know for sure and the on/off/on/off/on trick yielded nothing that i could tell.
c-code:
66-06
67-35
68-06
What do these mean? Anyone? And where can i go to find out more about them.
When i tried the on/off/on... trick it almost instantly displays the....DONE in the odometer section.
The truck isnt acting funny or anything and appears to be fine. Just trying to figure out if there may be a problem somewhere I am not aware of or one about to happen.
All help is appreciated. Thanks
Old Sep 22, 2004 | 07:19 AM
nord's Avatar
Hmmm.... Very serious, indeed!
66 - Door lock (all) either grounded or shorted to voltage
67 - Same as above.
68 - Driver door lock either grounded or shorted to voltage.
6 start cycles since 66 & 68, 35 since 67.
I'd be guessing you held the button a bit too long. Sometimes too much computer is a bad thing.
Now if you really want to drive yourself crazy, pull up behind a vehicle as you're about to turn and witness your signal light going completely out of sync with inside blinker.
Old Sep 22, 2004 | 09:28 AM
alrighty then....lol
guess theres nothing to worry about with the locks unless something starts to go wrong...
Thanks for the reply.
Busboy
Apr 10, 2011 02:23 AM
ScottGregory
Mar 28, 2009 08:14 AM
rschaer
Aug 6, 2007 09:02 PM
Crabjoe
Oct 4, 2003 03:28 PM
