A Pillar Ignition-on Wire
Old Sep 8, 2007 | 08:19 AM
PCM's Avatar
PCM
Exclamation A Pillar Ignition-on Wire
I've installed an Auto Meter transmission temp guage and have it all done EXCEPT the 12v ignition on wire. I have used the SRT Ram A pillar replacement from Genos that can accomodate 1 guage. It has worked out great. The wiring for the guage light goes directly into the dimmer switch. SO, my question is where do I tap an ignition hot wire for the sender power. It's imposssible to get to the cigarette lighter without dash removal nor are the wires even visible from under the dash. Of course, theres a bundle of wires under the dash near the park brake pedal. My question is, is there a wire I could tap in the A pillar bundle of wires for ignition on power. THANKS. PCM
Old Sep 8, 2007 | 09:03 AM
CD in NM's Avatar
On the 2006 trucks you can pick up a SWITCHED power source in the '100' pin wiring harness located under the dash near the pedals, look for a plastic box, the harness runs parallel to the box - the wire will be PINK with a YELLOW TRACER. That's what is suggested in the install instructions from Diesel Manors install information.
CD
Old Sep 8, 2007 | 09:34 AM
PCM's Avatar
PCM
Thumbs up
THANKS! Great pix and info on that web site. I appreciate your input
CD
Old Sep 8, 2007 | 12:19 PM
TonyB's Avatar
You can also steal ignition switched power from the cigarette lighter plug. +12 in Run and Accy.
Use the cig plug; NOT the power point. Cig lighter is closest to the driver.
Tony
Old Sep 8, 2007 | 07:30 PM
PCM's Avatar
PCM
Thumbs up
I got the t-tap tap & plug wire connectors and tapped into the PINK wire with YELLOW stripe. WORKS like a charm! Easy, too! THANKS!
Old Sep 8, 2007 | 09:29 PM
CD in NM's Avatar
Glad to hear that you got 'er done. Enjoy your gauge.
CD
Old Sep 8, 2007 | 09:51 PM
ripping r's Avatar
Tony
how do you get to the cig with out rippin out the hole dash?
Old Sep 9, 2007 | 08:14 AM
PCM's Avatar
PCM
GOOD QUESTION! Surprisingly, all the parts of the dash seem to fit pretty necely and tight. Minimal if no space between parts. I could not even see the back of my cig lighter due to the center console AND it seems to have a plastic panel behind it. So, I opted for the Pink wire with Yellow trace. It will get power with the key on in accessory mode, however.
Old Sep 9, 2007 | 10:56 AM
ripping r's Avatar
did you just use a wire tap? how did you splice in to it?
Old Sep 9, 2007 | 11:28 AM
TonyB's Avatar
It sounds worse than it is....on a laramie
1) Remove cupholder insert
2) Remove lower console
3) Remove dash insert just above console
4) pull center dash cover out...gently!
5) Splice wire
6) Replace in reverse order
Like I said...it sounds worse than it is. Also, tapping into the cig lighter means you are accessing a circuit that should be good for ~10-15A. It will be able to handle extra load with no issues.
Tony
Old Sep 9, 2007 | 12:23 PM
CD in NM's Avatar
The pink with yellow tracer is also a high amp circuit like the lighter circuit, so it too will be able to handle etra load. Plus, more convenient. I used a tap that allows me to plug in a spade, easily unplugged if need be. I also added a separate fuse tap in-line to the gauges right at the tap sight. It will blow long before it affects the trucks fusing. I prefer to install things that are easily accessed just in case I need to access them.
CD
Old Sep 9, 2007 | 06:25 PM
ripping r's Avatar
5) Splice wire
Tony
thanks! i will be doing mine soon. that does not sound to bad.
CD
do you know what else that pink &yellow wire feed? I know diesel manor says to use that wire with a fuse. also what size fuse did you use? I also like easy!but do not want to over load.
thanks
Old Sep 9, 2007 | 11:14 PM
PCM's Avatar
PCM
CD
DITTO! That is exaclty how I did mine. I ran the wires and the inline fuses (1for the light and 1 for the sender) in a manner so that they would be accessible by removing the end panel of the dash near the door hinge.
CStroked
Jul 7, 2005 10:55 AM
Stormin_Norman
13
Jun 23, 2003 12:20 AM
KATOOM
Apr 23, 2003 06:53 PM
D4Fritz
Mar 16, 2003 03:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
