paint????
Old Nov 30, 2004 | 08:54 AM
Graphite600's Avatar
paint????
While washing the truck yesterday I found the rear lower panel of the fender covered with small black specs that appear to be black paint, or something, most of them pop off if I scrape them with my finger, but what could I use to speed up the process of getting them off. I dont know how it got there, but I hope it will all come off!
Old Nov 30, 2004 | 08:56 AM
Squidward's Avatar
Any asphalt resealing going on in your area lately? Try Bug and Tar remover. Actually, WD-40 works just about as well.
Old Nov 30, 2004 | 09:01 AM
thanks for the tip! I'll try it, just spray and wipe?
Old Nov 30, 2004 | 09:47 AM
big_gatti's Avatar
Mothers clay bar system works well on all sorts of goo and paint overspray. It also leaves a nice smooth surface to make waxing a breeze. Mothers showtime alone will remove most junk too and wont strip wax. If that doesn't work, skip the bug and tar and use WD-40 but you will have to re-wash and wax the applied area.
Just some thoughts
Old Nov 30, 2004 | 01:11 PM
tryed the wd-40, with no luck these little beads are on there good! Will the clay bar remove them?
Old Nov 30, 2004 | 02:56 PM
bhoeffner's Avatar
Try clay magic, I got a lot of paint over spray on my truck a while back and it took it right off. Also had to buy a bottle of "final inspection". The Final Inspection is used as a lubracant (spelling) for the clay bar. Just spray on and rub clay over area. Took me 4 hours to do entire truck including washing and waxing.
The clay bar removed everything for my truck; paint, bugs, tar, and what ever else was on the thing. Looked better then the day I brought it home. Note get an ice pack for the sholder you'll need it if you have a lot of area on the truck to clean.
mullishacrew
Mar 19, 2012 09:05 PM
easinc
Mar 16, 2011 03:25 PM
lovin1stgens
Oct 30, 2010 12:33 AM
st.rodder2
23
Dec 17, 2008 10:47 AM
RJOS
May 27, 2007 10:19 PM
