p tires?
Old Dec 11, 2010 | 04:45 PM
trex's Avatar
p tires?
I got a great deal on some michelin a/t tires. Only problem is they are p not lt rated tires. I don't haul anything but do pull a 5k boat 10 miles on the wekend. I know its not recomended but what can this hurt?
Old Dec 11, 2010 | 05:28 PM
MikeyB's Avatar
I wouldn't use them. These trucks are way to heavy for P-metric tires. Heck, P-metrics suck even on a 1/2 ton!
MikeyB
Old Dec 11, 2010 | 06:06 PM
Rob's Red Ram's Avatar
P tires should NOT be on a 7000+pound truck.overloaded just with the weight of the truck alone nevermind people or a 5000lb boat.Safety first $$$$$ second.
Old Dec 11, 2010 | 06:20 PM
Danderson's Avatar
P=passenger tire. All the manufacturers use them for 1/2 ton OEM. In this age of ambulance chasers,I don't get it.
Old Dec 11, 2010 | 09:03 PM
trex's Avatar
I don't see a 7k truck
Old Dec 11, 2010 | 11:10 PM
annabelle's Avatar
Not worth the liability if you get into an accident......and mine is 4X4 and a 1 ton, but it weighs 8,000 lbs.
Old Dec 12, 2010 | 12:23 AM
Highway 4x4's Avatar
P rated no way, C rated LT's no way, D rated LT's are usually OK if truck not loaded, there is a reason these come with E's.
Old Dec 12, 2010 | 02:53 AM
brassnadz's Avatar
I run Ds on mine. Wouldnt even think of running a car tire.
Old Dec 12, 2010 | 08:32 AM
trex's Avatar
I understand what you all are saying. I agree a 4wd 1 ton dually is a heavy truck and needs the load range. These tires are about 500 lbs lower in load and I never carry anything but me. Lt tires are designed to be worked all day everyday at full load. Im just trying to see if it's been done and what was the result.
Old Dec 12, 2010 | 10:02 AM
whats the air pressure for those p tires?35 to maybe 44psi?be like driving with jello tires.Also if something did or does happen and ins or dot see's improper tires lookout neither will be to happy.All we are all trying to say is,It's not safe for You or the people on the road with You.
Old Dec 12, 2010 | 12:58 PM
trex's Avatar
Rob what does your truck weigh?
Old Dec 12, 2010 | 01:15 PM
MikeyB's Avatar
Don't think of this as a weight issue but as a heat issue. P-metrics being 44 psi max the tires are going to run much hotter than a same size LT at 60 psi or more. And it's heat that decreases the life of the tire and also can cause tire failure.
MikeyB
Old Dec 12, 2010 | 01:22 PM
ripping r's Avatar
If your not towing or halling heavy i dont see a problem. your not over loading the tires and keep them aired up. it probley rides nicer to with those on it.
15 Digger's Avatar
The lighter tires will also wear out much faster costing you more in the long run.
Old Dec 12, 2010 | 02:08 PM
Lower the air down on your D's or E's to 44 psi and see how it feels. Then head down the fwy on a hot day, try a few sharp turns. Remember also that the P's are not built as stiff so they will be even softer. They might be fine on the beach due to the bigger footprint.
