One Inch Lift for 4X2 Front End
Old Feb 16, 2008 | 01:51 PM
DBHMEH's Avatar
I want to raise the front end of my 06 4X2 about 1.5". Are there metal coil spacers avialable? If so, who carries them? Or, are the poly's OK? I have a friend telling me they may wear out.
Thanks
David
Old Feb 16, 2008 | 01:54 PM
txfiremedic's Avatar
Hi and welcome to DTR. There are several leveling kits for the 2wd. I'm running the Daystar 1.5 inch, but personally, I wish I would have gone with a 2 in. Heres a pic and you can see for yourself what the 1.5 inch looks like:
Old Feb 16, 2008 | 02:10 PM
DBHMEH's Avatar
Thanks TX, I'm on duty here in St. Louis. Was the install fairly involved? How did it affect the ride? Will an alignment be needed when done?
Thanks
Old Feb 16, 2008 | 02:14 PM
Im at the station today too! I had a local shop install it for me so I can't say on that, but as far as the ride, I can't tell any difference and yes, you will need to get the front end aligned.
Old Feb 16, 2008 | 03:26 PM
DBHMEH's Avatar
TX,
Were any other mods needed as a result of raising the front end? i.e. shocks,brake lines, pitman, etc
Old Feb 16, 2008 | 03:32 PM
No, not for the 1.5 in. I believe that if you go with anything more than a 1.5 inch then there are mods involved.
Old Feb 17, 2008 | 08:28 AM
MikeyB's Avatar
Looks good!
Personally I would go with the 1.5" if you tow heavy. Don't want to look like a Ford going down the road!!
MikeyB
Old Feb 17, 2008 | 01:51 PM
bigjohn04's Avatar
I did the 2.5" Daystars on my truck. You do have to put longer shocks in.
Old Feb 17, 2008 | 03:08 PM
bigjohn, was that the only change you had to make with the 2.5"s? Did you do the install yourself?
Old Feb 17, 2008 | 05:42 PM
TX Tech Wes's Avatar
Mikey, he has the airbags (read his sig) so I guess he doesnt have to worry about looking like a ferd goin down the road
txfiremedic, got any better after pics from the side view after the leveling and 285s (which was my guess on your tire size)?
wes
Old Feb 17, 2008 | 07:31 PM
RMCBRIDE's Avatar
1 and 1/2 or 2 inch lift
I have a 4x2 and would like to level the truck. I was thinking if it is possible to change the front end springs to raise the front end. Does anybody know what lenght the stock springs are? Does anybody know what length the spirings would have to be? Thanks guys for all of the help.
Old Feb 17, 2008 | 07:34 PM
dropped2500's Avatar
with the 2.5 all you had to do was put new shocks? Whats size? Does it level the truck out perfect or is the back a little lower? Id like to have the baja stance!
Old Feb 17, 2008 | 08:16 PM
chipmonk's Avatar
if it's the same as 4x4, you buy the springs by lift height. 2", 4", or 6". the other difference is the spring rate, which will tell you how stiff the spring will ride.
Old Feb 17, 2008 | 08:27 PM
Z06-LITE's Avatar
I have the two inch Daystar leveling kit on my 2004 2wd dually. No problems at all. Still running all stock components except tires and wheels. Please see my pics in my gallery.
Old Feb 17, 2008 | 08:31 PM
wes
Wes, that is a pic of it with the leveling kit and 265's (because of the 18" rims the 285's rubbed. Here is a pic of it with lift, stocker rims and 285's:
