Need tire recommendations 2004 Ram
Old May 19, 2008 | 09:42 PM
rbox's Avatar
It is time to replace the tires on my 2004.5 4x4. I want to stick with 265s in an all terrain. Something with good highway manners but that will still get me around in the dirt/mud/snow... I am looking at these tires:
1. Goodyear Wrangler Silentarmor
2. BFGoodrich Rugged Trail TA
3. Firestone Transforce AT
4. Toyo Open Country AT
My main concern is max. reliability as I travel a lot back home. Does anyone run any of those tires or have any experience with them?
Thanks
Old May 19, 2008 | 09:47 PM
SundayMoney's Avatar
I've had a few sets of the Toyos. They're an excellent tire. Quiet,smooth,and great in the wet/snow.
Old May 20, 2008 | 10:18 AM
acfr2105's Avatar
I haven't had any experience with any of those tires but the tires I've been running have been doing very well for me. They are Bridgestone Duellers A/T Revos. They are quiet on the road and grip good off the road. A set will normally run me a year.
Old May 20, 2008 | 10:31 AM
03RAM2500's Avatar
I have always liked the BFG's all terrain. They are quiet and always lasted a long time. They work pretty good light off- roading also. I went with a set of mickey thompson mudders this last time and I miss the quietness of the BFG's. If I had one thing negative to say about them, they seem to pick up a lot of rocks in the tread off a gravel drive and then throw the rocks out at highway speeds. I have a few chips behind my wheels from that but hey, its a truck!
Old May 20, 2008 | 10:52 AM
hubmonkey's Avatar
These are the ones I will buy when I nned a new set. My Neighbor has them on his 1/2 ton 2wd and he gets around in the snow just fine when I can't go anywhere with my michelins.
Hub
Old May 20, 2008 | 11:29 AM
rbox's Avatar
I am leaning towards the Bridgestone A/T Revo's even though they weren't on my original list. I like the tread design.
acfr2105, what size do you run in that tire?
Old May 20, 2008 | 12:04 PM
acfr2105's Avatar
I run 265-70-17 and the good thing about them is they are E rated so they can still handle a load
Old May 20, 2008 | 01:14 PM
rbox's Avatar
I think that's what I may go with myself. Thanks!
Old May 20, 2008 | 02:05 PM
acfr2105's Avatar
Not a problem i think you'll really like them ive had really good luck with mine i have a mile dirt road to go in to get to my house and i never have had a flat (knock on wood) and they grip really well in the dirt and in wet/snowy conditions
Old May 20, 2008 | 03:15 PM
RepairBill's Avatar
If you don't mind a little stiffer ride and shelling out money for rims, the 19.5 opton will give you 2 -3 times the miles on a set of tires.
Old May 20, 2008 | 03:22 PM
rbox's Avatar
I have seen those on DRW models. How does that work on a SRW?
Old May 20, 2008 | 05:50 PM
RepairBill's Avatar
Work great on mine. I have 50k miles on a set of Bridgestone M724. Mine are not very aggresive, but other tread styles are available. I used cast aluminum rims but steel rims and machined alloys are available too. Wear is excellent (mine have 60-70% left), but ride is stiffer due to the harder ribber. Load range is G on mine (heavy!), and traction is adequate in light mud and snow - they are not for serious off-road use, but I just carry 4 chains.
Old May 20, 2008 | 05:51 PM
RepairBill's Avatar
Check out Rickson Wheel (www.ricksonwheel.com) to see pics.
Old May 20, 2008 | 05:54 PM
RepairBill's Avatar
Oops, should be www.ricksontruck.com.
Old May 20, 2008 | 11:41 PM
rbox's Avatar
Thanks for the link! Not sure if I'm prepared to drop that kind of $$$ on rims and tires right now. Man those 19.5 traction tires look good though!!!
