Need a/c compressor clutch coil
Old Aug 11, 2010 | 11:37 PM
06ramdually's Avatar
Does anyone know where I can find an ac compressor clutch coil for a 2006?
Old Aug 12, 2010 | 12:59 PM
kingofdodge7131's Avatar
I would imagine its all complete unit these days, gotta get the complete clutch assembly its all i can find anyway
Old Aug 12, 2010 | 09:38 PM
Do you know where I can get the clutch assembly?
Old Aug 12, 2010 | 10:07 PM
04ctd's Avatar
my dealer had AC compressor for $326 or so.
i called all over and could NOT find just the clutch.
Old Aug 13, 2010 | 08:03 AM
1-2-3's Avatar
Just a plain ole guy
If you find it, the disadvantage to replace just that is getting it setup and gaped right. If that's not done, your going to be replacing them over and over.
Old Jun 13, 2011 | 11:30 PM
zulusafari's Avatar
Old thread, same problem!
My A/C compressor coil is shorted out. The compressor itself along with the rest of the system (condensor, accumulator, dryer, etc.) seems in good shape yet, so I don't see the need for a new compressor which requires changing out all the other parts. Where can one find a replacement coil and clutch assembly!?!?!?!?!?! I have seen threads about getting it done, and several nay sayers about setup, etc., but no one has listed where the parts were sourced. Why do I need to buy a $350 compressor and the rest of the junk, along with having the system evacuated and charged at a licensed A/C repair shop, when all I need is the stupind coil????I guess that is what happens when Dodge sources a Ford part for our trucks!
Old Jun 14, 2011 | 09:40 PM
Mr Jerry's Avatar
Josh, I have done it,its simple, just replace the coil, not the Assembly, the coils are on e-bay, if you need help i can tell you how to do it, or ask for my number and i will send it to you. enter this.
Ram Pickup Dodge AC Compressor Clutch COIL 06 07 08
Old Jun 20, 2011 | 01:03 AM
billinvancouver's Avatar
MR Jerry Help!
What kit did you use to fix your compressor, what was involved. What part of WA are you in.
Thanks
Bill
williamrlambert@yahoo.com
Old Jun 20, 2011 | 02:35 AM
Boudreaux's Avatar
comp clutch
Bill, go to e-bay,punch in Dodge 2006 air conditioner kits or try differrent key words.Always use dodge air condition in your key words. you will find a co that sells a clutch assembly, coil, clutch, & bearing. It is a good product with better springs than your Oem. He even e-mails you complete instructions on install for all 3 pieces. You do not have to install bearing if yours is still good. $95 bucks shipped. You don't have to pull pump or evac system. The hardest part is that the coil does not come with ihe factory connect, just 2 wires and soldering the wires under that truck will send you to the chiro.
I found a killer price on a comp and installed it, but ordered the clutch kit to put on my old pump to keep as a spare. Way easier install when pump is out. I am not affilited with this company and new to forum, so will not post any links in case it's a no no. good luck, Boudreaux
Old Jun 20, 2011 | 09:58 PM
zulusafari's Avatar
Good info all!
I got mine from gentleman going by Mooon101, and he sent email instructions. I am doing the relay listed in another thread, going for better juice for lockup. Parts look awesome, and the description was for a coil - not the entire kit I received! I just need to work on it this weekend and get my cold air back!
Old Jun 21, 2011 | 01:16 AM
Boudreaux's Avatar
Zulu that's the guy I was was refering to, awesome clutch, steel springs. if i read it right you got the whole kit, the coil and clutch are a piece of cake to install. the wires that are coming out of new coil need to be spliced into the old clutch factory connection to Tipm. Do your best on that splice. It is underneath the oil filter and always has vibration from cycling pump on off.
Another tip- be gentle with that small bolt in the center of pump it is small and weak, use a good 10 pt socket, if you break or strip that engineering marvel, you will have a bad day.
Also follow moons instruction on gap, simple and it works. Boudreaux
Old Jun 21, 2011 | 05:50 PM
zulusafari's Avatar
Does it matter which wire is connected where on the coil? One is shorter than the other, but both are solid black, no tracer color.
Old Jun 21, 2011 | 06:19 PM
Mr Jerry's Avatar
Wouldnt matter, its just a field coil.
Old Jun 21, 2011 | 08:06 PM
Boudreaux's Avatar
Mr Jerry is correct. The wires are staggered short & long so your splices would not be side by side, let us know how you made out
Old Jun 22, 2011 | 12:03 AM
Thanks for the info, I'll jump on ebay and order it up!!!
