Modulite installed, park lights dimming
Old Jul 15, 2010 | 08:35 PM
rconkin's Avatar
I installed the modulite unit on my truck tonight so I now have a right turn/brake light on my 5er again. The problem is that when either signal light is on while the park lights are on the park lights dim when the signal light comes on. I did start the truck thinking maybe it was just a voltage drop since it was not running but that makes no difference. Any ideas?
Old Jul 15, 2010 | 10:54 PM
RTillery's Avatar
Did you install the large power supply wire directly from the battery?
Old Jul 16, 2010 | 07:40 AM
gcssr's Avatar
check your ground wire, it is probably loose or dirty, hope this helps,
Grant
Old Jul 16, 2010 | 11:52 PM
Brad5502's Avatar
They have a heavy gauge power supply wire on the website I ordered from for $10. I all problems solved for the three trailers I tow. If you didn't order that, might give it a try.http://www.hitches-forless.com/electrical/modulite.htm
Old Jul 17, 2010 | 11:48 AM
CamperAndy's Avatar
If you used the scot locks to connect the wires you may not have made a good connection on the running light connection.
Old Jul 18, 2010 | 09:32 PM
rconkin's Avatar
Thanks for the replies, went camping this weekend and just now getting on computer. I did order the power supply wire and used it. I will check the connection to the park lights. I used the factory ground wire that goes to the trailer plug.
SOhappy
38
Aug 20, 2015 07:36 AM
Shovelhead
Dec 24, 2003 03:35 PM
wick
15
Nov 29, 2003 09:34 PM
Tob
19
Feb 27, 2003 08:04 AM
