Map sensor
Old Jul 28, 2007 | 08:56 PM
monnshyne's Avatar
Map sensor
Ok I have a quick question for all you guys that already know this.
How do you take what your scanner tells you on the map sensor and convert it over to PSI? My scaaner says Map ("HG) 75.3. This is what it maxes out to normal puilling is about 50. I know this isn't PSI by no means it's just I don't have the math formula to convert it over.
Thanks
Mark
Old Jul 28, 2007 | 10:45 PM
vzdude's Avatar
DTR's 'Go to Guy'
You need to change the settings on your scanner! It took me awhile, but I found it on my snap on. Cant remember where the heck it was now though!
Old Jul 29, 2007 | 02:37 AM
monnshyne's Avatar
LOL yea I wish I could but this isn't a Snap-On but a Actron instead and you can't swap it over so I'll need to do the math myself
Mark
Old Jul 29, 2007 | 08:33 AM
jrussell's Avatar
My laptop scan tool reads about the same peak value (74-75), but it's listed as "PSI". The minimum value I see is ~24psi at idle. I just assume it reads like that because there is boost fooling going on.
Old Jul 29, 2007 | 09:45 AM
monnshyne's Avatar
Could be. I don't use a uploader but I do use the Predator inline chip that does cheat on boost to the ECM. I'll remove it and see what it say without it.
Mark
Oh yea what laptop scan tools do you have and were did you get them from. I've allways wanted a program more because they will show allot more. Kind of scared to call Cummins and see what Insite costs.
Old Jul 29, 2007 | 11:36 AM
jrussell's Avatar
I use the one from Autoenginuity.com. The one from Cummins is probably much more powerful though.
The difference between the two figures on mine is about 50 at WOT. My actual boost is around 40-43psi at that time. It's confusing because I would assume boost fooling would show you a lower number, not higher. I need to give them a call about that and also to find out why the "calculated load" figures seem off.
Old Jul 29, 2007 | 01:11 PM
monnshyne's Avatar
Thank, you
I'll check that out.
Mark
Old Jul 29, 2007 | 02:23 PM
vzdude's Avatar
DTR's 'Go to Guy'
75.3"HG converts to 36.98 PSI @ 60 degrees. Here's a link to a unit calculator.
http://www.unitsconverter.net/
Old Jul 29, 2007 | 02:42 PM
jrussell's Avatar
Ah, so it does make sense then. I usually see about 24 at idle and 75 at WOT. The scan tool lists it as "PSI" but it must really be "inHg" instead.
24 inHg = 11.8 psi
75 inHg = 36.8 psi
Difference = 25 psi
Looks like the boost fooler is showing the ECM a max boost of 25psi. I wish I could use the scan tool without a boost fooler, but I assume that would throw an overboost code.
Thanks for the link, dude!
Old Jul 29, 2007 | 04:00 PM
monnshyne's Avatar
vzdude
Thanks man is just what I was looking for.
Mark
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
