Liner in engine compartment
Old Nov 27, 2007 | 09:10 PM
dylan's Avatar
Gents:
The liner towards the back of the engine compartment is starting to fall down on my truck.
Is there a fix for it, as of now it rest on my heater hose?
Regards
Old Nov 28, 2007 | 12:43 PM
ssandlin's Avatar
If you mean the liner that is on the underside of the hood, it's held in place by black plastic plugs, at least on my 06 that's the case. I had the one towards the rear of the hood, in the middle, just fall out. Went to the dealer and bought a couple (one for spare) and just replaced the plug. So far so good.
Old Nov 28, 2007 | 05:44 PM
EDR's Avatar
EDR
I second Scott's comments. When I was installing my gauges, I noticed my liner was a bit loose. Luckily I was able to just push the plugs back in tight and they seem to be holding up so far.
I think the engines vibration and the cheap design just cause them to work loose over time.
Old Nov 28, 2007 | 08:05 PM
CatDiesel_762's Avatar
Like EDR and SSandlin said. Get some new plastic retaining clips and wahers. If that does not work then try some 3M Headliner adhesive. Or get some aftermarket insulation and hang in the same spot.
Shawn
CZSteve
Mar 8, 2011 08:11 PM
tobyw
Aug 2, 2006 01:55 PM
04ctd
Feb 18, 2005 05:30 PM
MK4288
Jun 22, 2004 11:38 AM
