Lights going dim???
Old Mar 29, 2006 | 06:39 PM
slickr1's Avatar
Lights going dim???
Just came home and when I was coming down My road my lights were going dim then back to normal. Anyone have this happen ?? 06 CTD Mega.
Old Mar 29, 2006 | 06:40 PM
timcasbolt's Avatar
engine cold?
Old Mar 29, 2006 | 08:00 PM
Derek Timm's Avatar
Do a search on grid heaters. These cause dimming since they draw a ton of juice. Most likely not a problem.
DT<*)))><
Old Mar 29, 2006 | 08:10 PM
handymantim's Avatar
How long had you been driving before you noticed the lights dim? If you had been driving a while, which is implied in your post then it isn't the grid heaters or if it was the grid heaters and the engine was warm then that's a problem too.
Not sure if you can do this on an 06 but turn the ignition on/off/on/off/on and see if any codes show up in the odometer window.
Old Mar 30, 2006 | 06:24 AM
slickr1's Avatar
Lights
I had only taken a short drive less than a mile. The truck was not warm.
Old Mar 30, 2006 | 06:53 AM
Geico266's Avatar
Grid heaters cycling on & off, totally normal. Until you hit about 23 mph they will turn on & off. Helps keep the "cold engine smoke" down. If it's below 40 F plug your truck in.
Old Mar 30, 2006 | 12:15 PM
slorocco's Avatar
Are you saying it's based solely on speed, or is that assuming a cold engine also.
danalex
Dec 27, 2007 01:39 PM
larry30000
Feb 26, 2006 06:29 PM
s-mcbride
Oct 16, 2005 01:23 PM
Hired Gun
Jan 24, 2004 07:55 AM
95ramtough
Dec 9, 2002 10:34 PM
