Leaky clearance lights...
Old Dec 6, 2004 | 09:50 AM
dieselnewbie's Avatar
Question Leaky clearance lights...
Anyone ever have them?
I know someone with a 2003 CTD with leaks and water coming in thru the console.
Old Dec 6, 2004 | 02:14 PM
RonP's Avatar
I had mine all replaced and a while back when I asked, it seemed to be pretty common.
They usually crack where the screws go through. I have one that has cracked again already. Mine was leaking out by the sun visors.
Old Dec 6, 2004 | 02:22 PM
Jonesey's Avatar
Yes I have had the leaky cab light syndrome. You would think DC could come up with a better design by now.
Old Dec 6, 2004 | 07:22 PM
Miles PH's Avatar
On my 2004.5 the first week I had it FEB 10 th I had them "DC"dealer replace 2 lights . They told me it was a on going problem at the plant over tightening and causing them to crack. And water coming in by drivers vizier. But no moor problems. It should be covered by your warranty. Good luck with the problem
Old Dec 6, 2004 | 08:25 PM
Dave65's Avatar
I had mine installed by the dealer and they leaked til I sealed them myself.
Old Dec 6, 2004 | 08:28 PM
Captain's Avatar
luckly mine arnt cracked and dont leak yet. I was told by the dealer the only way to get new gaskets are to buy a whole light kit too. So I got a bunch of neoprean to cut my own gaskets with at some point in the future. That way at least the gasket will never go bad. Just have to be carefull not to over tighten them Iguess.
Old Dec 7, 2004 | 02:14 AM
SuperGewl's Avatar
OK here is the fix for the LEAKY Clearance lights. First pull the all off and clean up the area benegth them, lay some wax down while you are at it. Pull the screws out of them and get yourself some clear RTV. Put some in the holes on the clearance lamps and also seal up the cracks from the bottom also. Put the screws back in and install them on the truck. Yo won't have any more leaks from them this way and you won't have to get new ones unless yo break them completely
Old Dec 7, 2004 | 04:29 AM
Dodgezilla's Avatar
No problems yet with mine either..... (fingers crossed)
Old Dec 7, 2004 | 11:31 AM
CTDinMT's Avatar
Yup, my middle light cover gets condensation under it, but no leaks making their way into the cab. Gonna have the dealer replace it when I take the truck in to have the crappy factory stereo replaced. CD player is Tango Uniform -Steve
Old Dec 7, 2004 | 12:54 PM
KTNKA's Avatar
Buy 5 Orings 1/16 in thickness and so they are about 1/4 " away from the hole which is underneath the light assembly. Silicone them down on the bottom of the light assembly right on the gasket and screw them down evenly. Then put a small amount on the screw head to cover it. You can pry the silicone off the screw head when you replace the bulb and reapply a small amount on the head again.
Old Dec 7, 2004 | 10:12 PM
Patriot_RAM's Avatar
I get replacement lights number 4, 5, and 6 in the morning. Hmm.... Truck only has 5, that means at least one is on the second time around.
Old Dec 7, 2004 | 11:24 PM
War Nerve's Avatar
My '03 was back to the dealer twice for leaking lights. Water would drip off of the sunvisor mount and on to my right leg, and there was always condensation in the middle light. Luckily, no more problems like that with the '04.
Old Dec 8, 2004 | 04:41 PM
stevenknapp's Avatar
Mine will be in for it's third visit. First time they "resealed" all four. This time they are replacing one, but need to order it.
Water leaked from the sunvisor clip next to the center console. It would appear it collected at the bottom of the J shape of the clip.
RussianVolk
Jun 29, 2010 01:13 AM
Ramcam
Apr 7, 2007 03:43 PM
Mcmopar
71
Feb 27, 2007 01:58 PM
hotmopr
Jun 29, 2006 10:22 PM
cummins dsl
22
Jun 27, 2005 11:53 AM
