"Lampout" light and alarm?
has anybody been able to disable this anoying lamp out light system. I would like to install led's in all of my lights but can't because of the lamp out system. It would stay on all the time. I could buy resistors to combat the problem but then it is pointless to put led's in if they use the same power as normal bulbs..
it is not the bulbs, it is your circuit board, where the bulbs fit into.
i just went through this and i had to replace the circuit board and every thing is fine.
i also had this problem on one of my chevy's , it is a common problem with most trucks and cars using a circuit board in the tail lights.
it is not exspensive, and might be covered under your warrenty, if you still have some left.
anyway, replace the board , as you won't have a turn signal or stop light when the lamp out is lit on your dash, and could cause a problem with other drivers.
Well my "lamp out" light has been on now for over 3 weeks. Still no bulbs out that I can find, every light that I know of still works. Just waiting for something to actually stop working.
All my lights still worked.....none were out.........I was told from the vibration and bumps that if the elements touched............they are all dual elements..........that it would short out and cause the lamp out indiacator. I am not sure if this is true but I know none of my lamps were out and I replaced all bulbs and lamp out is gone.
JIM
JIM
My lamp out warning light and chime came on about a week ago. Three of the brake light bulbs went out. Luckily it was just before I brought it in for the 60k service. Dealer replaced all four bulbs no charge. But then again, it wasn't a cheap service...
TP
TP
Originally posted by GreenZ
Anyone now if the rear light pops out after the 2 screws next to the tailgate are removed? I could not get my lights to come out after removing the 2 screws. Maybe I need more persuasion or a Ford wrench?
I took out the 2 screws, inside the bed, but I can't get the light to come out?? Do I need to pull harder or are there more screws that I can't see?
it should be just the two screws holding it in... I struggled with my headlight the first time and was afraid of breaking it but the second time it just popped out. Just give it another shot and a good tug it should come out!!
Man! I hadn't heard anything about this before today. Mine just started doing it too. I was about to just start tearing things up to find that darn chime. It just startles you when it comes on for no reason!
Are these two screws beside or behind the taillight?
Also, anyone have the part number for the boards for an 03?
Well mine is still on and not lights out(almost 2 months). When a light stops working I will fix the light, until then I just ignore it. At least it has stopped chiming while I am driving.
I had to apply a lot of pressure after removing the two screws but it finally came out with enough force.
It wasn't the filiments inside the bulb on mine. The slot part of the bulb looked defective to me. A dollar bulb fixed it.
Digging up an old one from the grave...
Is there a part number for this circuit board? I know that if I go to my dealer, when I tell them I need a certain part without providing the part #, I usually get this:
Had same problem with mine. would chime run check bulbs nothing all were working. Then took both rear lights out and check bulbs and sockets REAL close and noticed at the base of one bulb the wire was melting into the plastic base of bulb and must have been breaking contact intermitantly. Changed bulb and used some emery cloth on tab in board and all good for months now.
Lamp Out Alarm
Good Day Every one:
My left license plate light socket became corroded and the alarm and light come on. In trying to find a replacement socket found out only a dealer item. Went there and they will only sell the entire lamp, len's & all for $52. Does anyone know how to turn off the Light Out alarm/chime.
Thanks
Iguide/Wayne
Thanks
Iguide/Wayne
