I found my power steering leak (I think)
Old Feb 28, 2011 | 03:23 PM
VaultRam's Avatar
Well for the past several months I've been chasing this **** leak down! Today I re-checked that all fittings were tight and they were. I know this leak is either coming from the reservior or the pump because I'll wipe everything dry and I'll see that everything on top is wet...when leaking. So I took of the driver side wheel liner and and checked all the fittings on the "T". I started messing with reservior and as I moved it back and forth, I could see it dripping at the bottom of the bracket where it mounts to the pump. I would rock it back and forth and the harder I did it, the more it would drip. Took the 4mm allen and tighnted the living snot out of it and it seems to have stopped the leak. I have heard about the cap issue and yes I cleaned that up as well.
Question, do you think my reservior is cracked since it seems to be leaking between that and the pump?...is that possible?
Old Feb 28, 2011 | 05:33 PM
VaultRam's Avatar
Well that didn't fix it. Still leaking a lot. Can anyone help me before I buy a new pump and reservoir?
Old Mar 1, 2011 | 09:43 AM
VaultRam's Avatar
Funny how common these leaks are on these third gens and no one has any advise.
Yes I've used the search function and I didn't find any answers.
Old Mar 12, 2011 | 04:42 PM
rjweiss's Avatar
my mechanic found the PS hose was bad...fairly common problem.
Ron W.
Old Mar 12, 2011 | 05:37 PM
AH64ID's Avatar
I would clean it up with something like brake cleaner (stay away from electrical) then put baby power on it, and let it idle for a little while. That should help pin-point the leak.
Old Mar 12, 2011 | 06:42 PM
MikeyB's Avatar
Most likely it's leaking at the seal between the reservoir and the pump. Just need to replace the o-ring seal between the two.
Checkout 100 Proof's post. https://www.dieseltruckresource.com/...power+steering
MikeyB
blackram2500
Apr 29, 2010 04:36 PM
ytodd
22
Apr 26, 2008 07:52 AM
Bad Ramer Jamer
Mar 26, 2007 07:42 AM
mkozlows
Jan 29, 2007 07:06 AM
Don H
Jul 9, 2004 07:47 PM
