husky mudflaps
Old Apr 26, 2010 | 08:22 AM
dieselnut932's Avatar
husky mudflaps
I need to get some mudflaps for my dually. I want a matching set for the front and rear. I was checking out the husky mudflaps, anyone using these?
Old Apr 26, 2010 | 11:29 AM
MikeyB's Avatar
I have the Husky Liners molded splash guards on my truck. Installed the guards about six years ago and no complaints.
MikeyB
Old Apr 26, 2010 | 08:14 PM
iml84bed's Avatar
I have the husky molded mudflaps on my 05 dually with no complaints, I love em.
Old May 14, 2010 | 06:44 PM
thanks for the replies. Went ahead and got the husky's... now just need to find time to install them. Any tips on installation?
Old May 21, 2010 | 09:34 AM
thenrie's Avatar
Yeah. Make sure you use the clear plastic paint protectors. You'll get paint damage eventually if you don't, where the mudflap rubs the fender.
Old Jun 23, 2010 | 09:24 PM
turtlesdove3's Avatar
Did you install it yet? I'm searching for some installation guides.
Old Jun 24, 2010 | 06:44 AM
thenrie's Avatar
No big deal, really. They are made to use the same holes your inner wheel well panels and trim use. I didn't have to drill any holes at all. They give you clear plastic stick-on paint protector strips that you need to stick to the area where the hard plastic mudflap will rub. Clean off the area where the protector goes with a cleaner that will not leave a residue, then do a "dry run" with the mudflap before you remove the protector's backing, to make sure you know exactly where it needs to go. You might even lightly mark where it goes with a pencil. Then remove the backing and stick the protector in place. Remove any air bubbles with a needle. Now install the mudflap. Voila! You're done.
Now that I'm thinking about it, seems like the protectors might have been decals you have to soak in water to apply. I might be wrong, though. If so, just drop them into warm water for a few seconds to loosen the back, then wipe a wet rag on the area where it goes. Lay the protector into place and slip the backing out from underneath. rub and squeege the water and air from under the protector. Use a needle to remove any air bubbles.
I like mine. I got both front and rear mudflaps. They fit well and keep most of the mud off my door step and rear fenders. The only negative I have found is that the rears might not be long enough on our Dodges to protect against rocks from the rears hitting a vehicle behind.
Buzz
Jul 7, 2004 08:39 PM
converteddzlr
Apr 20, 2004 07:38 AM
eswartz
14
Oct 26, 2003 12:21 AM
Berak
Mar 30, 2003 07:58 PM
