How to make check engine light go off?
Hey all, I was putting in a new air filter and I let my girlfriend start the truck with the intake tube off of the airbox lid to see how much air it sucks in... anyway, I forgot to plug in that little harness which I'm sure is what caused the engine light to come on.
I disconected the battery cables for 30 mins and that didn't help.
I put in the new K&N drop in the one that isn't flat, but cone shaped and it is huge!!! and man did it make a difference from a stock piece or the Nano drop in which is almost impossible to clean and it it clogs up too quickly for my taste which is killing my mileage.
the stock # is E-0776 and I have heard all the arguments over a K&N but I ran one for 180,000 miles on my last Dodge with no probs, till I sold her.
Disconnect cables, hit the brakes(light) to draw the last bit of power.
Also, a good way to check(if you didnt know) the code its setting, cycle the key three times quickly to on(not start) and on the third one it will display the code(s).
EDIT: Sorry, thats for 03-05s, I dont think it works on 06+(key cycling)
I had a false CES light two weeks ago, low voltage to injectors, cleared the light by unhooking batteries, hit brakes, no problem since...
Only unhook the pos term?
Unhooking the cables(s) dosen't clear the codes on any of the later trucks. If a minor and corrected CEL it will clear itself after a few good key cycles. The key off/on 3 times works all the way up to the 07's at least as it works on mine to read the internal codes stored. I have noticed you have to be a little faster cycling the key on the newer trucks though. My 04.5 was a little more forgiving on the key cycle speed.
I went and cycled the key about 10 times and started the truck and the engine light went off, took it for a drive and no light.
Thanks for the tip 06 Megacab and the rest of you that responded.
Negative cables, then just tap the brakes...
(03-05 trucks)
After you hook them back up, gauges flash all the way over, then start the truck, and it cleared my light.(But thats because it was just a false light, nothing was actually wrong, thats why you need to check the code first, again 03-05 trucks
(03-05 trucks)
NJMurvin
Sep 25, 2009 11:17 AM
mgoodlander
Apr 18, 2008 04:57 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
