Headlight issue plz help
So the passengers side headlight is out. High beams, running lights both work. Bought replacement bulbs, but light is still out on low beam? Anyone had this problem or know what the deal is there? Thanks
i had a similar problem back a few years ago. on my 03 truck. i had a low beam that didn't work, i had replaced the front control moduel, but that didn't fix it. so i pulled out the drivers headlight, and thats where you can see the wiring to the FCM, i went ahead and started to pull back wires and tape, and i found a wire that had a break in it, it was pretty much in 2 pieces, it was easy to see, i fixed that wire and i had lights again. maybe check out the wiring from each light to the FCM, which is behind the drivers light mounted on the inner fender. you will have to pull back tape, or wire loom.
mtdoragary
Nov 7, 2013 08:31 AM
jlipskoc
Oct 24, 2005 01:16 PM
