Happy Happy Happy
Re:Happy Happy Happy
Me thinks this guy runs on three cylinders.
<br><br>The only thing that ran on three that I had was my Kawasaki triple two stroke. Now that was one "runnin'" machine. Wow, that thing was fast - - almost as fast as my Cummins. ;D<br><br>ThreeStrokeBob
Fiver,
I have one of those Nipponese Tractors that runs on 3 cylinders, only has three cylinders. Called a Ferd/New Holland, others like it called Kubota, John Deere. One half of a 6 cyl.
If for cold starting they may over fuel and thereby increase inner cyl temp.
That would cause the sound to be diffrerent.
You seem to know quite bit about synthetic oil. I just changed the rear diff oil to synthetic and now I get a slipage noise turning left or right. Took it back to the dealer and he added an additive to reduce the noise. Should I change back to regular oil? 1999 3/4 24V.
[quote author=poogan link=board=17;threadid=7547;start=15#73631 date=1038573322]
[/quote]
Hey Poogan, first post. Let me be first to welcome you to the site. Great place to hang around.
No, stick to synthetic and use the additive. Just takes a little bit - - dealer should know how much to add. It seems the 2003 does not need the additive, but the older ones did.
Bob
[/quote]
Bob
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=Sierra Phil link=board=17;threadid=7547;start=0#73145 date=1038430113]<br>A warm up higher idle speed during warm up I can believe? <br>[/quote]<br><br> ;D On the 02 and down, this is indeed the way the high idle feature worked. It would gradually begin dropping cylinders until the truck was idling at about 1100 RPM on 3 cylinders. It did work to keep cylinder heat up, but the truck sounded like someone had punched holes in all the pistons. I hated it.<br><br>The 03, or at least mine, simply has a high idle to 1000 RPM that kicks in on start up. All the cylinders are still firing, AFAIK.<br><br>Rod
Derek Edgar
Apr 10, 2013 09:54 AM
