H2 Rims and Tires
H2 Rims and Tires
I've searched this whole forum, and can't find info on this,, but I know I've read it here before I think....
How many people have put on factory rims and tires off of the Hummer H2? I seem to remember hearing that they are a direct bolt on?
The reason I ask, is I am vacationing for another week in Ocala Florida, and there are alot of lifted 4x4's, and alot of H2's. I should be able to find a new set here no problem. So, any help appreciated as always!!
Happy non-denominational winter holiday! (quoted from Larry the Cable Guy!!)
Also, if anyone actually knows of any in existence in the Ocala, Orlando area, that would be great too!!
how many? lots... direct bolt on? kinda, bolt patern is correct but the hole for the hub needs to be opened up to 4.775", via milling in a perfect world, here on this world a number of methods have been used, holesaw, dremmel, etc. you should try to get thehole as close to perfect as you can via milling. the lugs will center it ( use your stock nuts ) and your set. they will come factory ballanced just be sure to rotate them at short intervals, the rear ones tend to wear fast depending on how hard you press the skinny peldle anyway.
May 29, 2009 10:24 PM
flyright
Oct 16, 2007 08:20 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Mark Hodowanec
15
Nov 11, 2004 08:50 AM
