gps install
Old Dec 26, 2007 | 01:47 AM
gus's 03's Avatar
Cool gps install
just added a Garmin 660, awesome unit.
ill start ya all off with a night shot.
day shot
trip computer shot
side view of how its mounted
botom looking up
with our windshielsd mounted as far forward as they ar i didnt want to have to reach for the screen. i also didnt want the tattle tale suction cup on the windshiels atracting would be thives.
Garmin provides a smoth plastic disc to mount the suction cup to, it has 3m body tape on the back side. i cleaned the botom of the " eyebrow " on the dash with rubbing alcohol, mounted it. then because of it being atached to the dash, abd as hot as it gets in the summer, i decided in typical overkill fasion to reinforce it. i drilled a piolet hole in the puck, counter bored it, then ran a taperd head screw in. problem was it wound up mot being air tight any more. problem solved, i pulled the screw, pumped some Goop into the hole, started to run the screw back in, but coated the back of the head, then once flush, wiped the excess over the screw. started the truck, let the heat run for a few min (35 deg out). SOLID!
as far as wiring, i taped the cig lighter leads for an aditional power port. normaly i'd just cut the plug off garmins cord and hard wire it, but this one has an fm transmiter/reciver in it. so not wanting to loose my real time traffic updates, mp3 thru the sterio, and hands free etc... well you get the picture. i had read that the transmiter is kinda week, and that for best results to put it as close to the antana as possable, so i routed it behind the dash, to the pasenger side.
performance: awesome. this has the latest generation gps chip in it. as some of you gps nuts out there know, cold starts usualy take a while. when it first arived i powered it up inside the house, no view of the sky, not even a window close. within less than a min it had locked on to 17 satalites and had position locked to 20 feet... INDOORS! walking into another room that had a window droped it to 15 foot accuracy. stepping onto the back porch, drops to 10feet or less, and thats without wae or what ever it is turned on.
user interface: this is where Garmin shines. navigation is simple. intuitive. contrast is exelent, the fuzy cell phone pics dont do it justice.
the icing on the cake: i can read it with polerised glases on! it actualy almost makes it look 3d...
Old Dec 26, 2007 | 03:10 AM
TexasCTD's Avatar
Thanks Gus. Looks good. I am about to get one too (prob Garmin Nuvi 650) and looking for ideas on where to mount it. Are you going to take yours in and out everyday?
Old Dec 26, 2007 | 10:21 AM
D45's Avatar
D45
Looks really good! Nice custom install...........I might give something like that a try!
I just got a Magellan Maestro 4250 and it is great...other than like you said, trying to mount/access it on the windshield!
Old Dec 26, 2007 | 11:07 AM
donnee's Avatar
Only prob here in Calif. is the fact that a state law says the unit cant be mounted to the windshield.
So I m going to remount mine on the dash mat.
Old Dec 26, 2007 | 01:08 PM
power plant's Avatar
Great install but where did you hook the power into???
Old Dec 26, 2007 | 02:37 PM
RamWheelsBy4's Avatar
Picked up a Garmin nuvi 350 last week for $299, so far I am very impressed with the unit. I mounted mine in the same location. A little close to the shifter but out of the way, easy to see and touch and meets all state laws for mounting.
Old Dec 26, 2007 | 04:14 PM
gus's 03's Avatar
[/QUOTE]
i bought a add on power port and ran the wires to the factory cigorette lighter under the dash. .then to get the plug close to the antana, i ran it all under the dash, its located just above the hvac behind the glove box.
Old Dec 26, 2007 | 04:24 PM
gus's 03's Avatar
not every day, but when i do i leave the bracket. the 6xx series has the power atached to the bracket so it makes it quick and clean. alot of the cheeper ones have a seperate power cord.
look into the 660.. the extras are worth it.
http://www.tigergps.com/index.html is where i got mine. its only $469 the 650 is $449. for $20 its worth it if only for the hands free. but you also get the fm transmitter with it (sells seperatly for almost $200) and blue tooth.
heres a quick comparison on all of them http://www.tigergps.com/index.html
Old Dec 26, 2007 | 04:27 PM
Sixxer's Avatar
I just got my Garmin nuvi 650 and so far I love it.
Here is where I mounted mine.
Old Dec 26, 2007 | 10:09 PM
BAH's Avatar
BAH
just got myself a Garmin 360, awsome unit, but wish I got the wider screen. Thanks for the mounting tip, I was wondering how to mount it lower, i have mine on the windshield next to the mirror. Mine also has the power cord attached to the mounting bracket.
Old Dec 27, 2007 | 12:31 AM
TexasCTD's Avatar
Yeah I had considered the 660. The cheapest I have found one on EBay is $419.
http://cgi.ebay.com/GARMIN-NUVi-660-...QQcmdZViewItem
The 650 can be had new for $324. http://cgi.ebay.com/Garmin-Nuvi-650-...QQcmdZViewItem
I was really considering one of the 250w's, but for the little price difference I would have to go to the 650. But another $95ish I just don't know about getting the 660. Im not sure I would use the blue tooth or FM Trans. I have an ear piece blue tooth now....
Thanks for the pics of the install......and info though!
Old Dec 27, 2007 | 07:16 PM
ColdCase's Avatar
I use a proclip with good results. No glue no hassle.
http://www.proclipusa.com/Default.asp
The 7200 is a bit heavier than other units, so the brace is needed.
Old Dec 29, 2007 | 02:40 AM
Shortshift's Avatar
day shot
trip computer shot
botom looking up
Oh this is beautiful! Now i know where the 680 is going tomorrow.. Thanks for sharing your masterpiece!
Old Dec 29, 2007 | 04:36 AM
gus's 03's Avatar
no problem
Old Jan 7, 2008 | 07:51 PM
haulin-rv's Avatar
Those look cool, a bit pricey though. I think I may bite the bullet and try one! Thanks for the link!
