Gooseneck installation ?
its not going to hurt your frame. Although DC may not like it. There are several guys I know that have welded goosenecks in on the frame on the new generation trucks. I stuck with a bolt-in system just for warranty issues.
Gooseneck
I went with the B&W Turnover Ball. Granted I haven't used it for a G-neck trailer, I have the fifth wheel adapter for my 32' fiver. Bolted in easy enough, had to drill holes in my brand new truck bed, but a couple of hours with my brothers help and all was good.
I personally would not, just because they make kits that are even a no drill install.
My old GN was welded to the frame, and it became a PITA over time working around it.
Current truck has a B andW.
On the bolt on kits do you drill through the frame ?
Btw you are down the street from me.....Discovery bay here.
I'm no expert and have no experience, but I have always been told to never weld to these frames!
Again, I can't back up this statement. But this is the first time I've heard of welding to the frame being ok.
I would think a bolt up kit is strong enough…our axles are bolted to the truck and they hold up ok…just my uneducated, inexperienced, non-informed opinion.
Either way, good luck!
The B and W is a complete bolt on, the only drilling you have is a 4 inch hole in the bed, and 2 1/2 holes in the bed for the saftey chains.
Take Welndmns advice, no reason to frill thru frame when it is not even necessary. I put one on my old 87 and had to drill thru frame. It worked great, but now they have better stuff. Get a B&W like Welndman said and you will be totally satisfied IMO
From: Different City each Week of the Year, Currently: Newtown Ct
i dont have a gooseneck, but have seen a few installed the same way as my 5th hitch. I did drill my frame, but only through one side of the box tube. Then i tigged a filler wire to the end of each grade 8 bolt, and used it to fish through the frame. Huge PITA, then held in place. With a lock washer on both sides of the frame, impacting held it all together. I was told that if i welded to the frame, i would void the warranty on the whole truck. (These dealers make me sick)
....and a good settup!
