Gears
Old Mar 15, 2007 | 12:48 PM
goodeyesniper75's Avatar
Gears
I HAVE 4.1O GEARS A 6" LIFT ANF 35"s WITH 39'S SOON, WHOUDL IT BE BAD TO SWITCH TO THE 3.73 GEARS? IS THERE SOMTHING I COULD SWITCH TO JUST TO MAKE IT A LITTLE MORE DRIVABLE ON THE H/W?
Old Mar 15, 2007 | 01:10 PM
dodgezilla04's Avatar
with those size tires, why do you want a higher gear ratio? are you running really high rpm at speed with 35's? 39's will effectively raise you final drive ratio a ton!(lowers cruising rpm). you might be better off going with an overdrive unit instead of changing both gearsets. the price will probably be about the same in the end, but the OD will give you more gear options.
Old Mar 15, 2007 | 01:12 PM
kawiram's Avatar
I dunno how well you'd like the 3.73's when you put on the 39's. I think 39's and 4.10's would be a fair compromise with the cummins.
Old Mar 15, 2007 | 01:14 PM
Ok Cool....i Was Just Wondering, Thanx
Old Mar 15, 2007 | 07:46 PM
gus's 03's Avatar
the 39's will drop you from abot 1650@ 60mph down to almost 1450....
3.73 would be good for another 100 rpm drop. so unless you cruze @ 80+ all the time it'd be a loosing battle...
fyi 3.73 w/ 39's @ 80 mph is 1800 rpm.....
BigJohnston
20
Jul 14, 2019 10:58 AM
Roarinbear
Dec 27, 2009 09:44 PM
93beater
Feb 28, 2007 09:28 AM
Turbodude
Jan 4, 2006 09:13 PM
walexa
30
Apr 8, 2005 10:26 AM
