Fuel Level Sender went out
Old Jun 11, 2009 | 09:10 AM
mkelly9779's Avatar
Ok this is probably a dumb question, but my fuel level sender went out and I am having trouble getting the electrical connector loose on top of the fuel tank. Is there a trick to getting it loose? Does the electrical connector on top of the tank control the fuel level sender and the fuel pump because I only see one electrical connector there?
Old Jun 11, 2009 | 11:45 AM
mkelly9779's Avatar
bump
Old Jun 11, 2009 | 12:37 PM
1-2-3's Avatar
Just a plain ole guy
Remove bed bolts and raise it up and block it, then reach in and get it.
Old Jun 11, 2009 | 02:21 PM
rogers259's Avatar
IIRC there is a small plastic slide lock on the top of that electrical connector. You have to slide that all the way over then it will release the connector when you depress it. Yes I believe its the only electrical connection the the sending unit.
If your going to replace the sending unit you might want to just go ahead and either drop the tank or remove the bed. It will make removing the sending unit easier and if you want to go ahead and install an aftermarket fuel pump (FASS, Airdog, etc) then now would be the time to do it.
Old Jun 11, 2009 | 03:14 PM
mkelly9779's Avatar
With the risk of start a war, what aftermarket fuel pump is better to get? Is one easier to install than the other (require less motifications or none)?
Old Jun 12, 2009 | 07:53 AM
mkelly9779's Avatar
Nobody have an opinion?
Old Jun 12, 2009 | 09:09 AM
klx650a2's Avatar
I like my fass hplp. They were the only ones that replied to me stating their pump would work at -40. Everyone else did not reply to my emails asking for info.
jc07874
Jun 22, 2006 09:14 PM
kawi600
Dec 26, 2005 09:50 PM
MOAGGIE
Jun 29, 2005 09:14 PM
BIG MIKE
Jul 15, 2004 10:36 AM
