Fuel Level correct?
Old Oct 23, 2004 | 08:27 PM
kingofdodge7131's Avatar
Fuel Level correct?
Alright I must be going crazy cause i even checked and im sure it doesnt stay put. Today when i got home i shut the truck off and I had only used 1/8 of a tankk of fuel ( the mark between 3/4 and full) hop in tonight to go get a pizza and its down to 3/4 tank. Im likek hum. So now to help my memory i took a pic wiht the phone and ill find out tomorrow. Wonder why it does this, , if it does do it
Old Oct 24, 2004 | 03:17 AM
FastZilla's Avatar
Fuel gages are NEVER linear. Full to 3/4 may be 100 miles but 3/4 to 1/2 may be 150miles. Make, model, year, doesn't matter. Just my experience anyway.
Old Oct 24, 2004 | 07:14 AM
Goodys1ton's Avatar
Mine is doing the same thing. I especially noticed it on a trip to Michigan, When stopping for a rest I would notice the fuel gauge was near the 3/4 mark. Then when starting the truck to leave the rest area, my fuel would not be even near the spot I thought it would be. It made it hard to really travel because I was unsure of the fuel I had used. I had asked a question in the past and the response I got was that there is a TSB for the fuel gauge sending unit. I looked but was unable to find anything, but I still plan on going to the dealer.
Old Oct 24, 2004 | 12:24 PM
yeppie now i dont feel so retarded
Old Oct 28, 2004 | 06:57 PM
burlhall's Avatar
Fuel expands when it is hot and contracts when it is cold. This may or may not be what you are experiencing.
Old Oct 28, 2004 | 07:51 PM
Pointing Labs's Avatar
Are you on level ground. My driveway is on a slant so if I back in I get one reading in the morning if I pull straight in I get another...Just a thought...
Old Oct 28, 2004 | 07:59 PM
yeah, it does it everywhere. not just the driveway at home.
Fuel does expand and contract , but not enough for a guage likek we have to notice , let alone 1/8 or more of a tank worth
Old Oct 29, 2004 | 02:55 AM
Goodys1ton's Avatar
The gauge on my truck takes a little longer to return to the full mark when I fill it up. It used to pop right up, but now it has a slow surge type motion to it. It is definitely nothing to do with the temperature. At least in my case.
Old Oct 30, 2004 | 10:22 PM
Diese's Avatar
mine does it ust like trhat too.
Old Oct 31, 2004 | 06:50 AM
AaronT's Avatar
Temperature, and grade(slope), does affect reading. It is also time/level dampened to prevent indication moving up and down due to fuel slop in the tank.
From starting cold and running a given amount of time the fuel in the tank will warm up due to return.
Overall I think the gauge works pretty well except at the low end of the scale. I think I have more than 8% remaining when on E based on fillup's to the neck.
Old Dec 7, 2004 | 04:40 PM
cryo333's Avatar
My truck the other day read below empty on the gauge. My wife had been driving it and I thought she had run it low as she will often do. However after stopping to buy fuel it only took about a quarter tank. It has fluctuated like this before but not this bad. It may be worse due to a current cold snap in our weather. If anyone has ideas on a fix for this problem I would appreciate hearing them.
Old Dec 7, 2004 | 06:52 PM
JHardwick's Avatar
It has been my experience gas or diesel that a cold start in the morning will always show less fuel than you had the night before.
Was it heated fuel? Tired and not wanting to stop on the way home? I dunno?
I've noticed the same thing, and also noticed that as the truck warms, the fuel gage reads higher ............ check it out!
Old Dec 7, 2004 | 06:55 PM
Back when i started this post, The temps between when i got home and the next morning only changed 5-10 degrees. I cant say ive noticed the problem as much anymore. But ive also quit caring trying to get good mileage haha
Old Dec 7, 2004 | 06:59 PM
JHardwick's Avatar
Doesn't matter, the fuel is going through 2 pumps and the extra returned to the tank.
Old Dec 7, 2004 | 07:11 PM
and it would matter. Because when i came back the next day i had less than when i left it
Which would make sence in the gets cold senerio but not 1/8th tank. Anyway For the most part it doesnt matter. I attributed it to time relaps. Where it more less took electronic snapshots of the fuel level and showed it to ya. but if ther that far apart thats also sad
