Fuel Filter changing
Old Aug 10, 2007 | 06:55 PM
02dodge2500ctd's Avatar
Hi,
I was wandering how to change the fuel filter on an 06 dodge 2500 ctd. My father and I are new to diesels and still in the learning process. His truck is just now hitting 15,000 miles so I thought it was about time to change it. Also is there a certain fuel filter recommended?
Thanks for any advice
Old Aug 10, 2007 | 07:16 PM
Roperteacher's Avatar
Genos garage makes a 7 Micron premium filter. About 15.00. CHanging the filter is not too difficult:
Drain canister by sliding the YELLOW lever over to the left. When fuel stops, put the lever back where it was!
Open the top of the canister and pull the lid/filter out as one unit.
Look in the canister for large particles and dirt. Wipe with LINT FREE cloth if necessary.
Remove old filter fom lid and remove rubber o-ring
Place new filter on and new o-ring
Slide the filter back down into canister and HAND TIGHTEN... DO not over do it!!
Turn key on and BUMP starter until pump quits. Turn key off and back on again and bumb starter again.. Repeat 3X
Fire it up!
Old Aug 11, 2007 | 12:58 AM
Rob C's Avatar
Dont forget to lube the new o-ring with some clean diesel or motor oil to make sure it seals right and doesn't stick the next time you pull it off.
Old Aug 11, 2007 | 01:25 AM
AlK's Avatar
AlK
Here you go step by step with picturres.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Aug 11, 2007 | 01:25 PM
Just changed the filter.... did everything like I was told and it worked great. Thanks for the help
Old Aug 21, 2007 | 06:59 AM
Scottygl62's Avatar
What size socket for the filter cap? Thanks in advance.
Old Aug 21, 2007 | 07:30 AM
pik's Avatar
pik
I believe it is one inch.
Old Aug 21, 2007 | 08:23 AM
AkitaSumo's Avatar
For my 06, I had to go out and buy a 1 1/8 socket. You will also find that a 6 point socket works better for this application.
Old Aug 21, 2007 | 09:15 AM
LongRanger's Avatar
I changed my filter for the first time last week. The instructions provided here were very helpful. I do have a couple of quick questions. Does anyone know the size of the drain hose. I want to extend mine as suggested in the instructions. Also, I noticed that my canister did not drain completely. Is that normal. Thanks.
Old Aug 21, 2007 | 09:29 AM
rockcrawler304's Avatar
I forget the hose size and I am not by my truck to measure but as far as the fuel not draining completely, that is normal. Just use a good lint free rag to soak up the small amout that remains in there. I use a long pair of needle nose pliers to hold the rag to get it all the way down and nice and clean.
Old Aug 21, 2007 | 10:56 AM
Triplggg's Avatar
You can use about two feet of 3/4 ID hose to slip over the drains hose.
Old Aug 21, 2007 | 01:35 PM
LongRanger's Avatar
Thanks for the help. DTR is the best.
flinn101
Dec 31, 2005 06:55 PM
kajngrl
Mar 8, 2005 11:08 PM
faurotus
14
Feb 27, 2005 11:40 AM
Slice
13
Jul 23, 2004 06:07 AM
debolton
24
Jun 29, 2004 09:22 PM
