fuel filter
fuel filter
i went to the cummins dealer today to but a fuel filter and also question the white chalkey substance on the outside of the canister that iwas asking about in my other post. Anyway they had a 10 micron fuel filter. which is best for the 04.5 5.9ltr? I know i can get a 7 micron from fleetguard but wouldn't it clog easier?
Thanks!
Thanks!
I would buy the 7 mircon size filter. I believe that some guys are even using a 2 micron filter rating but this is with a by pass set up. The better the filtration the longer your pump and injectors will last. If you are worried about plugging care a spare filter with you. Change this out if and when you sense plugging. I also change my filter every 10K miles, cheap insurance and carry a spare 7 micron filter.
Thanks!
Thanks!
Only 3 filters meet OE spec
OE/Fleetguard/Cummins
Donaldson P550800
Baldwin PF7977 (actually exceeds)
Any other filter won't meet the specs.
Baldwin PF7977
I would return it.. doesn't meet current spec
I am probably going to go 20K before changing all 3 filter.. I have yet to see a psi drop from plugging.
Very easy, couple of hours. All you need is the install kit (make sure you get enough hose, probably have to order extra) a drill and a tap.. And if you want to make a skid (depending on where you put it), you'll need some cardboard and a good machine shop.
Amsoil bypass for 04.5
What would i need to drill and tap for? For the mount. The kit looks like it has 2 lines, one goes to the oil cap and one goes into the top of factory oil filter mount. Is that all it is? no tapping the pan or the block? How many more quarts of oil will the system hold on the 04.5?
