fuel filter
i went to the cummins dealer today to but a fuel filter and also question the white chalkey substance on the outside of the canister that iwas asking about in my other post. Anyway they had a 10 micron fuel filter. which is best for the 04.5 5.9ltr? I know i can get a 7 micron from fleetguard but wouldn't it clog easier?
Thanks! |
I would buy the 7 mircon size filter. I believe that some guys are even using a 2 micron filter rating but this is with a by pass set up. The better the filtration the longer your pump and injectors will last. If you are worried about plugging care a spare filter with you. Change this out if and when you sense plugging. I also change my filter every 10K miles, cheap insurance and carry a spare 7 micron filter.
Get a Baldwin #PF7977 filter. It has a 5 micron absolute filtration rating and it's the best filter you can buy that will fit directly in the stock fuel filter canister.
Originally Posted by racemydodge
(Post 2432849)
Thanks!
Originally Posted by 92'1stGen
(Post 2432977)
Only 3 filters meet OE spec OE/Fleetguard/Cummins Donaldson P550800 Baldwin PF7977 (actually exceeds) Any other filter won't meet the specs. |
lots of people run 2 micron with no problems and not in a bypass configuration. just fyi. :-)
Originally Posted by Ducman82
(Post 2433298)
I am running 3 filters on my OE LP, 20um, 5um, 2um and have yet to see below 5.5psi even towing. |
what do you use for 5um ah64id??
I've been running the Fleetgaurd 7 micron from Genos for $14.95 with no problem. Sure beats the 10 micron at the dealer for $40!
Thanks for this post, it reminded me I'm due to ghange it out.[coffee] |
Thanks for the replys... So even though the microns are such a smaller number it has no potential for clogging?
well, if you have filters clog that fast, you got some baddddd fuel. but then that also means your injector pumps and injectors are safe and the filters did there job
AH! thanks makes sense now. i will probably use the 10 micron (fleetguard) that i purchased yesterday.. a least for now.. $18.00 at Cummins bridgeway!
Learn something new eveyday Thankyou |
(Post 2433442)
(Post 2433496)
How many miles do you go before changing the fuel filter?
I just might take it back. Now for a completly different question... How hard is it to put the amsoil by pass on my 04.5 ? |
I am probably going to go 20K before changing all 3 filter.. I have yet to see a psi drop from plugging.
Very easy, couple of hours. All you need is the install kit (make sure you get enough hose, probably have to order extra) a drill and a tap.. And if you want to make a skid (depending on where you put it), you'll need some cardboard and a good machine shop. |
Amsoil bypass for 04.5
What would i need to drill and tap for? For the mount. The kit looks like it has 2 lines, one goes to the oil cap and one goes into the top of factory oil filter mount. Is that all it is? no tapping the pan or the block? How many more quarts of oil will the system hold on the 04.5?
